Question about Dell Vostro 1700 Notebook
Unable to get into safe mode
I turn on the computer and hit F8 but still only get a blue screen that says "an error has been detected and windows hass been shut down to prevent damage to computer"
  • Sharad Anand
    Sharad Anand May 11, 2010
    give the error code at the bottom stop 0x000000??
    Problem Solver:
  • 3 Answers
To Repair Blue Screen and Safe Mode
Posted on Mar 13, 2011
  • 58 Answers
Please tap the F8 key as soon as you restart. keep tapping it . If you still cannot go to the safe mode and the normal mode, you may need to reinstall your windows.
Posted on Nov 01, 2009
    Novelist:
  • 225 Answers
"a blue screen error" is different from "an error has been detected and windows hass been shut down to prevent damage to computer" if you are asked by the computer to do safe mode and its just circling around then try repairing the windows using the os disc. once you boot to the dvd rom you boot to the os disc then instead of reinstalling os try to repair it first. just follow the instructions from the screen.
Posted on Oct 04, 2009
  • jovanni cabanag
    jovanni cabanag Oct 06, 2009
    try to do repair first then after repair try boot in safe mode.
  • jovanni cabanag
    jovanni cabanag Oct 10, 2009
    try f2. if f2 will not work which is same thing with f8. your keyboard keys might not be working. try an external keyboard first. then update the bios. then restart computer. if keys or f2 and f8 still not working then have it replaced.
    Scholar:
  • 76 Answers
Hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
  • black_pnix Oct 12, 2009
    hi,
    -this could be a possible hardware failure
    -run diagnostics on the computer; while the computer is off, press and hold the Fn key then press the power button at the same time, if any error is found, contact manufacturer, if no error is detected it is a Windows problem and you need to reinstall Windows
    cheers
I have a compaq presario cq 60 to and when I turn it on it just sounds like it's going to start up and goes to a blank bluish black screen if I did it says the main screen and then it goes to that after I...
The blue screen typically would have a error message on it. I would recommend hitting the F8 key once a second after turning the computer on to get the windows diagnostic menu with choices such as safe mode. If you can select this then try a system restore point to when the computer was working properly. If you are unable to have it start up by hitting the F8 key then you either have a failing hard drive or a corrupt windows.
Dec 25, 2014 | Computers & Internet
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
COMPUTER - BLUE SCREEN
what is the error of the blue screen showed? etc Stop :0X00000FE
Jun 08, 2012 | Dell Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Unable to have safe mode screen come up from hitting f8
When the F8 key doesn't work, there is another (less desirable) way to force the computer to start up with the option screen to go into safe mode is to interrupt the Windows start-up process. As soon as the Windows screen comes up showing that it is booting up, remove the power from the computer. When you restart, Windows will detect that it did not start up correctly on the last attempt and will automatically go into the option screen to allow you to choose Safe Mode.
Feb 22, 2010 | Sony VAIO PCV-RS710G PC Desktop
Windows shut down to prevent damage
You need to boot your system into Safe Mode by pressing F8 just before the Windows startup screen loads, once in Safe Mode do a system restore to a previous date to when your system was working.
This should sort out your problem.
Sep 09, 2009 | Dell Inspiron 1525 Laptop
Blue Screen
You could try turning the computer off at the switch when this happens. Sometimes it is a very temporary problem. You would need to wait a few minutes then turn it back on and restart your computer.
Aug 01, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Getting blue screen after start up
Try booting up to the recovery CD, it sounds like a software conflict error that is locking up your computer.
Try 1st if you can get into safe mode (hitting F8 when you first apply power to the computer, till the safe mode screen comes up)
Then try booting up to the last known good configuration (same F8 different selection on screen)
THEN try the recovery CD.
Jul 16, 2008 | Computers & Internet
Safe mode business
safe mode automatically comes up when you didn't shut down properly. Just select boot as normal or last known good configuration then you are good to go.
uninstall any new hardware or software you have recently installed to cause the problem in the first place. If you haven't installed anything then windows should just start normally.
good luck
smeags.
Jan 22, 2008 | Computers & Internet
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Dell Vostro 1700 Notebook Logo
628 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
