DO NOT BUY Durabrand PS-712CDB Shredder
My PS-712CDB shredder has never worked. not even once, walmart won't replace
    Problem Solver:
  • 15 Answers
Yeah, these are junk.
I actually have one that blew the control board and is not repairable... but all of my gears and such are perfectly fine.
Anyone want to buy mine? :)
Posted on Jul 18, 2015
SOURCE: My shredder stopped working
This shredder is supposed to reset after 15 minutes.
Posted on Dec 10, 2007
SOURCE: Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Posted on Feb 24, 2008
SOURCE: My Durabrand Shredder, model WM6X,.
I have the sam e problem. I just so happen to be one of those 'fix it myself people.' I disassembled the shredder to find that one of the plastic wheel mechanisms was broken. You know the wheels with grooves in them that is usually found in a clock or watch. The problem is, I don't know where to find a replacement. I doubt that home development stores like Home Depot, Ace Hardware, or Lowe's has it, but I guess I'll have to check. I came across this question while looking for the manufacture of the shredder to order a replacement part. I'll probably just buy a new shredder before it's all said and done.
Posted on Nov 10, 2008
SOURCE: NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Posted on Mar 22, 2009
  • 3 Answers
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
Posted on Jun 04, 2009
The shredder has no power
What kind of shredder is it? Try adding shredder oil into the opening to soak up the papers that might have jammed the shredder.
If that does not work - does the power light come on, if there is such indicator on this shredder?
Since you mentioned that it had overheated, there is a possibility and a thermal fuse that is part of the motor had been triggered and needs to be replaced.
May 05, 2016 | Shredder Office Equipment & Supplies
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
Nov 10, 2014 | Fellowes Powershred PS-65C Medium-Duty...
There seems to be a power ise when switch ingages breaker shuts off
I own a Fellowes PS 60 shredder.
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
I advise you NOT to use your shredder if it is causing the cicuit to shut off_it may start a fire!
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 11, 2014 | Fellowes Powershred PS-60 Shredder
Can you put oil or wd40 in shredder
NO! Do not use those lubricants.
I have used Silicone lubricant for many years and it does not and has not caused any problems in my PS60. Spray it across the top of the cutters and manually run the shredder (without paper) forward and reverse for a few seconds. This will lubricate all the cutters. I do this only once until my collection bin is full. Once full I empty it and lubricate once again.
Aug 15, 2013 | Fellowes Powershred PS-60 Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
Fellowes Powershred PS 60CC stopped working
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
Jun 19, 2009 | Fellowes PS60C-2 Shredder
NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
May 26, 2009 | Office Equipment & Supplies
Shredder won't run unless Istrike it on the side.
go buy another one , stick this lemon in the box and return it ! lol
sounds like you got a bad solder joint thats causing an intermitant problem until you bang it and complete the connection,, or a switch inside is bad or dirty , open it up check it out .
Mar 10, 2009 | Techko SH1524CP Shredder
Nov 01, 2008 | Office Equipment & Supplies
650 people viewed this question
jasbo
jasbo
