Question about Sport & Outdoor - Others
I have a wildwood le 25bhbs and the only towing lights working are my signal lights. can't get running lights or brake lights to work. I saw where it looked like the towing harness may have been pinched. So I repaired that, but, they still do not work. Any ideas? Is there a fuse somewhere I need to check? Do I need to hook the trailer up to my trailer hitch before they will work? Is there a wiring diagram or repair manual somewhere I can get? Any help would be greatly appreciated. Thank you.
  • 85 Answers
There should be an inline fuse, check that first.
Posted on Oct 03, 2009
Trailer lights come on when van lights are on but turn signals don't work.
The turn signal bulb circuit on the trailer MUST match the towing vehicles turn signals. Example: Tow vehicle turn signal light is the same bulb as the brake light, then the trailer must match. If the tow vehicle has a separate turn signal (amber bulb located away from the brake light) then an adapter is available that will send the correct power to the trailer so everything works correctly. The adapter can be found an auto parts stores, RV supply stores and some truck stops too.
Nov 15, 2015 | Cars & Trucks
No trailer lights. No brake lights running lights or turn signals. Plugged into tow vehicle. All lights on tow vehicle working.
check the 7 pin plug for oxidation clean connections and try again if not ok check cable for lights maybe pinched
Aug 30, 2013 | KZ 2013 Sportsmen Classic 200
2005 sienna turn signal light comes on when i push the brake
sounds like a crossed wire , I saw problems with the brake light switch that is located on the brake pedal
Nov 28, 2012 | 2005 Toyota Sienna LE
Trailer wiring problem. Tow vehicle is a 2008 Grand Caravan with 4 wire plug. Double checked, plug function works fine. When trailer is plugged to tow vehicle with tow vehicle lights OFF the trailer...
Most likely the brown wire from the trailer connector is connected to a constant battery voltage source, and it should be connected to the vehicle running light circuit, however someone might have wired the trailer connector up that way on purpose so that the trailer does not draw power from the vehicle running lights and possibly damage the vehicle running light circuit. (Dodge/Chrysler vehicles do have delicate lighting systems) Here are some images to help assist you, and the 4 way connector is the same as the 5 way connector just without the blue wire for the trailer brakes.
Jul 06, 2010 | 2008 Dodge Grand Caravan
Rear turn signals and brake lights out. Front signals and rear tail lights work fine.
the brake lights and the rear turn signals should be the same bulb check the bulbs to make sure they are not blown does your third brake light work if all brake light are out and the bulbs are good check the brake light switch on the brake pedal
Nov 04, 2009 | 1986 GMC C1500
My chevy z71 96 running lights work, but not right brake/blinker
check for a short it could be anywhere in the line
Feb 14, 2009 | 1996 Chevrolet K1500
No running lights on boat trailer towed by 2008 ford f150
You can purcahse a tester which will connect into the F-150's wiring harnes. If the led lights up, the problem is witht he trailer's wiring harness. this tester will indicate the proper operation of the brake light and turn signals.
Dec 27, 2008 | 2008 Ford F 150 2WD
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
