Question about Philips HTS3450 System
Mine buzz for about a month and now it is turning red light and no sound..... anything I can replace to fix it?
  • 20 Answers
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Posted on Jul 18, 2008
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Buzzing alarm sound before ignition
The yellow or red light would mean a control board that is bad or going bad. The buzzing sound could just be the transformer not uncommon to hear a buzzing sound from the transformer.
Dec 16, 2009 | Heating & Cooling
Playstation 3 will not work
sounds like your system overheated. the thermal compound needs to be replaced. you may need to have your gpu and cpu reflowed also. i fixed mine when i received the error. dwdpcrepair@gmail.com
May 20, 2009 | Sony Playstation 3 (PS3) Console
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bozzing sound
maybe need to replace instrument cluster. had mine replaced under warranty.check with audi
Jul 13, 2008 | 2004 Audi TT
My new Razar V3a makes buzzing sound
If the buzzing is coming from the keyboard then it's a known problem/feature. Got the same on mine when the keypad is lit up, so rag Motorola, who said sorry, known feature with that model.
Aug 29, 2007 | Motorola Mobility RAZR V3
Buzzing noise
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. I used a NTE382
replacement and has worked fine ever since.
Hope this helps
Aug 26, 2007 | RCA RS2640 CD Shelf System
Philips HTS3450 System Logo
169 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
