Question about Linksys Wireless-G WRT54G Router
My lap top wireless signal varies from weak to good when accessing home router when connecting at home.
  • rcaballero3 Sep 28, 2009
    same location,
  • luuuunatic
    luuuunatic May 11, 2010
    At the same spot in the house? Or are you moving around?
  • 496 Answers
Your signal can be affected by a lot of things from cordless phones to microwaves also the placement of your router is key, if its next to a cordless phone then chances are your going to have some interferance also the amount of space between you and the router try moving the router to a nice high location or a more central location in your home if you have 3 floors then the middle floor will work best. try those things out and see if it helps
Posted on Sep 30, 2009
My WRT54G2V1 is now producing a poor or weak signal to the 20nd computer. I have reset it and poeered it down a couple times
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2012 | Linksys Computers & Internet
Can I upgrade the antenna on my actiontec gt701wg router?
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Aug 01, 2012 | Actiontec GT701WG Router (actiongt701wg)
I have a belkin wirelss router for the lap tops. but i got a desk top computer which it is hooked up to but is causing a low wifi signal when i am using a messenger and when i have the video call on a...
1. this possibly due to 2 things
a. You have the desktop to far from the wireless router.
b. You may have an issue with decreased bandwidth by using the video calls.
May 30, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I purchased a D Link (Model # DIR 601) along with a Retail Plus USB Adapter. My router was set up so that I could bring it home and plug it in. I was not supposed to have any issues with it. My Lap top is...
check to see if your wireless connection is on on your laptop and set to work with your router - check to see if your laptop's wireless signal is b/g/n - if it's only an "n" - and your router is a b/g - then you will need to purchase an "n" class router...
normally, routers do not "just work without issues" when you bring it home and plug it in - it should have come with a setup disk or instruction guide - have you completed the steps to connect?
Feb 17, 2010 | D-Link DGL-4500 Wireless Router
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Dec 26, 2009 | Acer Aspire One PC Notebook
I got a new router (Netgear W..8.)for my home
try puuting the wireless access point on the middle and atleast 5 ft of the ground this will increase your signal slightly also make sure that there is no cordless phone especially the base near the wireless access point.
Sep 15, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
I cannot get my lap top to connect to my wireless router
Start logically eliminating possible causes. Start with the router (is it transmitting, weak signal, encrypted signal). Next move to the laptop (wireless device on, does the operating system see the device and shows its working) Once youve eliminated both of these, look at the laptop's operating system itself (viral infection, trojan, internet security program lockdown, misconfigured firewall).
Apr 03, 2009 | HP Pavilion Ze4900 Notebook
Do I have to have a wireless roator for my laptop?
you can buy a wireles linksys usb for your lap top and have a wireless router linksys stationary and the lap top usb ..... will pick up the signal for your lap top, i have a usb port linksys and it works great, but u do need a router in your home to pick up the signal
Jan 21, 2009 | Dell Latitude 100L Notebook
Emails
if it says 'no server' that means your wireless internet connection signal is weak. try to find a location where you can get a strong signal
Oct 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Speedstreem ss2623
the signal strenth is always good>and try this login to ur router and change the channels use 11>or 1>and delete all temp files and cookies and clear history>and reboot the lap top also>and rate me solved if its helped
Oct 27, 2007 | Siemens Efficient Networks SpeedStream...
Linksys Wireless-G WRT54G Router Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
