Question about Konica Minolta bizhub C450P Laser Printer
Empty scrap box on C451...can't find tray - Konica Minolta bizhub C450P Laser Printer
Its in the finisher. Push away the finisher from the machine and you will see the punch scrap case in the upper area of the attatchment side of the finisher. You may just have to open the door on the finisher that is on the right side facing the copier.
Posted on Oct 08, 2009
Code c202 bz c451
This sounds like you have a piece of paper behind tray one.
1. Turn the machine off
2. Take out tray 1
3. Remove paper
4. Insert tray
5. Turn back on
If that doesn't help, you have and issue with the paper pick up motor. This is 99% of the time not the issue. The paper behind the tray is most likely your problem.
Oct 08, 2014 | Konica Minolta 4053-401 Black Laser Toner...
Printer is only printing to the bypass tray instead of tray 1 where it should be printing
First, check your printer properties and make sure you are not telling it to go to the bypass tray.
If you are set to auto tray and its still trying to pull out off bypass tray. Check on the copier to make sure tray 1 isn't set for a special type of paper. If it is, change it to plain paper.
Sep 30, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
How to reset error code c0105 on konica c451?
C0105 Tray 3/4 feeder transportation
motor turning at
abnormal timing
The lock signal remains LOW for a predetermined
continuous period of time while the
motor remains stationary.
1) Check the M25 connector for proper connection
and correct as necessary.
2) Check the connector of M25 for proper
drive coupling and correct as necessary.
3) M25 operation check
4) Change M25
5) Change PFTDB
6) Change PRCB
Jul 17, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
How to disable tray4 on konica c451
Remove the tray(4 screw) and disconnect the tray motor.
Jul 16, 2014 | Konica Minolta bizhub Office Equipment &...
C-1183
Sir/Mam,
Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the top tray has to just touch them.
Jan 17, 2014 | Konica Minolta bizhub Office Equipment &...
Punch scraps box full
Please the copier model.The box is located theoretically in finisher part.
Feb 08, 2013 | Konica Minolta bizhub C250 All-In-One...
Bizhub c451 ERROR CODE C-1183
Elevation drive assy. for the output trays. did some one leave some boxes under the trays or a trash can.? Need to remove the reset the output trays to the correct location. Recommend a qualified KMBS tech do it
Sep 18, 2012 | Minolta bizhub 200 All-In-One Printer
Trouble Code C-1183
Your machine output trays hit something like a trash can or boxes store under the machine. Have to gain access to rear section of the finisher to reseat tray elevator drive assy.
Jan 18, 2012 | Konica Minolta KONICA BR BIZHUB C451...
I have a problem with a bizhub c451
sometimes especially when printing a pdf there is a box on the first print screen that pos up that says print actual size deselect that and then it will default and print on the paper that is available
Jun 16, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Mar 06, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub C450P Laser Printer Logo
312 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
