Question about CHE-EZ Snap Digital Camera
Computer says camera not found but it is install and connected to pc. whentrying to turn on camera it doesnt stay on. goes right back off and not able to take pictures.
Eu Am Camera Web Si Nu merge Scrie CAMERA NOT FOUND
Posted on Feb 08, 2010
I have a Lumix DMC-F3. There are pictures on the internal memory i am trying to upload to my computer. The USB cable is connected, the camera turns on (in play mode) and nothing happens. The manual says...
Go to "My Computer" and locate the camera's drive - it should be detected and show the camera as a device connected to the computer - if it's not then check the "Device Manager" to determine if the driver has been installed. If the driver is not installed, re-install it by loading the disc that came with the camera. You can also reboot the computer while the camera is connected and powered to automatically install the driver.
Jan 20, 2011 | Panasonic Lumix DMC F3 Digital Camera
Whenever i connect my galaxy 3 to pc, it shows that new hardware found but not installed properly.....even kies doesnt work......mass storage showing error doesnt connects to pc....i tried after turning on...
sir you have to install the galaxy pc suit to the computer.and then connect the datacable from phone to the computer for transfering the files.................
Dec 24, 2010 | Cell Phones
Registering my camera
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Apr 11, 2009 | Olympus FE-330 Digital Camera
My camera will not take pictures
Whats your camera make / model?
I have found this problem in the past mainly on samsung cameras. All I found was bad connections and poor solder joints.
connection problems with ribbons mainly. Samsung seem to prefer tinned ends as opposed to gold plated ribbon connections and these are just waiting to discolour and then fail.
Bad connections will drain batteries very fast and especially if your using cheap ones
Mar 15, 2009 | Cameras
Cannot download pictures from camera to PC
you might need to go to the manufacturers web site and download the drivers for your camera. or if your camera came with a CD isert that into the computer and install it before connecting your camera again. if that doesnt work you will need to buy a fifteen in one card reader for your memory card. that will plug right into the comuter and you will take the memory card out of your camera and put it in the card reader. then you should be prompted that something has been inserted into you computer.
Nov 06, 2008 | Sanyo VPC-E760 Digital Camera
9300 aspire notebook webcam not working
hi there, i had the same problem back a few month ago. the solution for me was, i twisted the built-in camera 180 degree a few times, after that, i heard sound indicating my system found a new hardware and it started to install them, which in my case, the webcam ^_^
maybe the connection is the problem, mine is acer aspire 5580 laptop.. hope this help
Oct 29, 2008 | Acer Aspire 9300 Notebook
PC NOT ACCEPTING USB
On a similar post, my reply was....
A couple of things you can try:
1. Insert the Camera's USB cord to another USB port of your PC;
2. While disconnected from the PC, verify that the pictures are still inside the camera's memory;
3. Reset the camera (power on/off);
4. Check the camera's batteries;
5. Reboot your PC with the camera attached via the USB;
6. Remove the memory card from the camera and try uploading using a card reader;
7. Uninstall all instances of your USB in your PC's Device Manager, reboot and allow the PC to auto-detect  and auto-install necessary drivers; and
8. Verify that the software/drivers for your camera are installed correctly with no yellow or red markings.
Hope this be of some help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 01, 2007 | DXG Technology DXG-308 Digital Camera
Possible PSU problem?
sounds like a bad power supply to me.
Oct 21, 2007 | Gateway GT4016 Desktop PC
Downloading photos
Hi, Most present day digital cameras are recognizable by a Windows PC as an external removable drive. You have to connect the camera using a USB cable (in some case, a firewire cable) to any of the USB ports of your computer. Give your machine a second or two to recognize and auto-install the needed drivers/software. The PC normally auto displays content of the camera (now recognized as possibly drive "E" or something). Thereafter it is a matter of copy/paste or drag-0n-drop to your preferred folder in your PC (more often My Pictures inside My Documents). Hope this be of some help/idea. Post back how things turnedout or should you need furtherinformation. Good luck and kind regards.
Sep 16, 2007 | Kodak Easyshare C813 Digital Camera
UPLOADING
first, open Windows Explorer and then search for the drive letter that Windows has automatically selected to be your camera's memory card. If you cannot find it (remember to right mouse click over each letter to see a short description). Once found on Windows Explorer, double mouse click it and then search all camera memory folders for the video files. You can then right mouse click and copy each file and then past (rt. mouse click select paste from pop-up sub-menu) each file onto your pc hard drive.
Aug 01, 2007 | Samsung Digimax S500 Digital Camera
CHE-EZ Snap Digital Camera Logo
124 people viewed this question
Top CHE-EZ Cameras Experts
Are you a CHE-EZ Camera Expert? Answer questions, earn points and help others
