Question about Garmin StreetPilot i3 GPS Receiver
Batter low message when plug into lighter holder
Why am i receiving this message, when the tool in plugged into the lighter?
  • Bair1 Dec 27, 2007
    I Have the same problem as Floyd. What is happening? Received as a christmas gift and is brand new out of the package. Barry
  • db323248 Jan 06, 2008
    Just got the Garmin nuvi 200W series for Christmas. I used it for a total of approx. an hour when I started getting a low battery signal. Now when I try to turn it on it shows the name Garmin, searching for maps and then shuts off.
  • 174 Answers
Sound as though the I3 is not getting power from the lighter. Hook the garmin to your laptop and turn on the laptop, now turn on the I3, does it still shows low battery message on the screen? If the answer is yes then the USB connector has failed (know problem with the I3). There are many unit sold on ebay with broken USB connector. If the I3 doesn't show Battery Low then the lighter cable is defective.
Posted on Dec 31, 2007
My location is stuck at last place visited. It got mailed then wont leave the last place.
Are you talking about the Last Position or Location..... The Last Position is where the GPS came off the cradle or holder... once you connect it to a cigarette lighter adapter and remove it, it retains the Last Position... to create the Last Position when plug into lighter, remove it from Holder /Cradle then turn off unit... this will create last position... to find it go to your Favorites it will guide you to your car
This feature is awesome if you park your car somewhere, you can always find it by going to your favorites ... last position
Nov 04, 2010 | Garmin Nuvi 350 Car GPS Receiver
My Magellan Roadmate doesn't work anymore when I plug it into my cigarette lighter. It says the battery is low and it is shutting down. The unit did not come with a battery charger so I am confused about...
there could be a few reasons why this is happening....
there should be a light on the car charger that comes on when you plug it in, if it isnt on when not plugged in to the gps, but while plugged in to the lighter...either the lighter fuse is blown, or the charger is defective.
if the light is on, on the charger and it still wont stay powered on, it probably has a bad usb port (very common on this model) but it could also mean the charger (if not factory) is not compaible with the unit.
another way you can try and charge it (if you determine the chargers at fault) is to hook it up to your computer via the usb cord that should of been supplied with your unit.
HERE is your manual..it will show you the differant charging options..there is also updates on that page if you need them
let me know if you need more help.
bill
Aug 17, 2010 | Magellan RoadMate 1470 GPS Receiver
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
Jan 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
HAVE NO LIGHTER THAT WILL ACCEPT NEW PLUGS
there are ways u can charge your gps 1 is to buy extension for your lighter i know that the plug is very big adapter is about 6.00 to 15.00 dollars.
also battery life after full charge is about 45 min not long at all
your lap to will charge it
ha hope u and your tom tom are very happy
ps keep it pro k bye bye get it
Dec 17, 2008 | Tomtom ONE GPS Receiver
LIGHTER FOR MY SATURN
Probably would have been a good idea to purchase a LED 12vdc tester while at the auto parts store. If the original holder is in the vehicle and the fuse was checked. The next thing you need to do is take the 12vdc tester and touch one lead to the side of the holder and look inside and see a center contact at the bottom of the holder, touch the other lead from the tester to that contact. If your light turns on then you actually have power there. If not the fuse to the lighter is out. You can not visually check a fuse, they must be tested. If you have power try to plug in another lighter. If you have to change or add a new holder the center wire is power and the ring or frame is negative. Depending where the lighter is located I have found coins, gum wrappers etc. in the holder you may also want to make sure nothing is in the holder.
Oct 17, 2008 | JVC KD-G230 CD Player
Turns off after a few minutes
Have the same problems, can't figure it out yet
Jan 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin 330 street pilot keeps shutting down. Only 3 mos. old and has been connected to cigarette lighter. What is the problem? I need a manual.
Make sure that you age getting power from the plugin.
Test: With the unit OFF plug adapter into cigarette lighter.
The Garmin should turn on automatically. If it does not,
you are not getting power to the unit. Make sure you have
good connection at the holder.
Generally it powers off by itself because it is not receiving
power from the plug.
Oct 22, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
