Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer leaking ALOT of water before and during the rinse
My Kenmore Elite top loading wsher is leaking ALOT of water before and during the rinse cycle. What can I do?
  • 5,911 Answers
You will need to remove the exterior casing of the washer to access the interior and determine where the leak may be coming from. Follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If the leak is coming from the front of the washer, most commonly this is caused by a leaking drain pump. The pump is located in the front directly below the wash tub. The pump is not serviceable and must be replaced if it is damaged.
Some other items to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the area UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
If you determine the pump is damaged and needs replaced, the following link explains how:
http://www.fixya.com/support/r397092-replacing_water_pump
Prices can vary between these sites so shop around for the best deal. NOTE: Use the part number from the Sears site and use it to "Search by Part Number" on the other sites. It makes it easier to find as some sites may not have your model number listed, but will still carry the part.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
Posted on Sep 28, 2009
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite, water leak
Check the mix valve area where the water enters the machine, during the fill.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite
Luckdan209
your washer is not agitating -
1. Check that water level switch works
2. Does it attempt to move when selected? Washer timer contacts may be burnt.
3. Your motor could be bad - washing spinning different ckts
Regards
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
80 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
