Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio Dryer wont close
I have a cabrio dryer. The "female" part that engages the door stop has broken. There is an identical one on the other side in case you want to change how the door opens. How do I get the "female" part out so I can exchange them?
  • 23 Answers
Sorry to say but they do not come out without breaking usually. You should be able to buy a new one from a local appliance store for next to nothing.
Posted on Sep 29, 2009
HOW DO i RUN DIAGNOSTIC CODES ON THE WHIRLPOOL CABRIO ACCUDRY DRYER
This unit has a belt switch ( W10411937) located on the motor frame, you should first check to see if the belt is not broken, or has not come off track. This can be done by disconnecting power and removing the toe panel to view inside the unit. Pleazer Appliance...
Dec 27, 2014 | Whirlpool WED5500XW Electric Dryers
My epic z dryer wont start the door female part is broke will this cause the dryer to stop working?
Yes, most dryers have a door interlock switch that shuts the dryer down when the door is opened. It is the female part on the body of the dryer (not on the door). If this part is broken, it can prevent the dryer from working.
Feb 24, 2014 | Dryers
My start button on my whirlpool cabrio dryer is not working
there are several components that could cause two of them would be a broken belt switch and the door closed switch
Nov 24, 2013 | Whirlpool Dryers
2001 volkswagon cabrio power windows on driver side wont go up and passenger window wont go down, stopped working all at the same time
The Cabrio electric window issues are most often related to a bad Window regulator. My wife owns a 2002 Cabrio, that had a mis-behaving drivers window. After inspecting it, I found one of the cable roller guides was broken, causing the cable to snag when using the window open / close. I had a local garage order the regulator for me, and then I disassembled the drivers door and installed the new regulator (problem is now solved). Additionally, her passenger window stopped working, however, if you listened carefully, you could here a click sound when the button was pushed. I took this door apart as well, removing the regulator, I found it was jammed. Carefully, I removed the cover concealing where the cable rolls up, and was able to free the pressure. Once this was done, the window worked fine.
Oct 31, 2010 | 2001 Volkswagen Cabrio
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
Go to: RepairClinic.com
to troubleshoot your appliance.
You'll need the make & model #.
Nov 16, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
195 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
