Question about HP Computers & Internet
Hp 6820s will not power up.
Led light near AC power supply is blinking in rapidly in orange color and then switch to blue color.
at same time power led is light on but when led at ac switch to color blue power led turns off. and again forever loop.
ty
  • mislav_cavar Sep 29, 2009
    no i did that same problem happens.. and i tray force boot whit power cord out and w8 30 sec and then plug in .. also i dismantle notebook and find that bios battery cell was leaked out . and the acid was all over mother board but i did not find some clue of damage or that some parts are burn or something like that.
  • Anonymous Mar 26, 2014
    The power light at the AC jack lights, but the power on light at the switch doesn't light. Occasionally the unit will turn on, but this is a rare occasion. Any suggestions greatly appreciated.
  • 788 Answers
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
Posted on Sep 28, 2009
Power indicator blinking orange and white
Mym7 stops charging the battery every now and then to allow the battery to discharge. This extends the life of the battery and changes the state of the battery light.
Feb 21, 2014 | HP Pavilion dv7-7000 dv7-7023cl B5R45UAR...
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
My laptop won't start
Does the HD light turns on?
If not, try to open HD bay, disconnect and reconnect disk.
Mar 22, 2013 | HP Compaq nx6125 Notebook
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
My Dell inspiron 518 will not turn on when power button is pressed. Green LED on back of power supply lights and orange LED on motherboard turn on. No fan operation on anything. Thinking it is the switch...
Green LED on PS means it's getting AC power. Orange light on motherboard means it's receiving power from PS but it may not be the correct voltage. The power supply isreceiving power from the source but is unable to properly distribute it to thecomponents. This can be caused by a defective power supply or a defectivemotherboard. Just to make sure that nothing else is causing the problem, removeany PCI cards like modem, video card, sound card, etc... Remove the memorymodules and disconnect cables to CD/DVD drives. Look at the USB ports to see ifany are damaged.
Feb 14, 2011 | Dell Inspiron 518 Desktop Computer
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
Jan 27, 2011 | Nintendo DSi Matte Blue Console
What do the various led light colors mean? I have
The LEDs each indicate something is conected or normal. There is one for hard drive activity, power, battery, and wireless. Blue is good. Orange is bad. First take the charger to a shop to have it checked. If bad replace it. If good the the problem is either battery or the connector on laptop. Since the battery is new it sounds like the connector to me.
May 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Orange blinking light
hp colour laser jet 2550n while giving printing command it shows orange led blinking it dosen't print please help me.
Jul 24, 2008 | HP Color LaserJet 2550n printer + HP Color...
Computers & Internet Logo
995 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
