Question about Bosch SHV68 Built-in Dishwasher
My SHV6803UC/15 seems to be cycling properly, but it's not cleaning the way it used to. I noticed a lot of soap residue all over the glasses, dishes and wall and base areas. We do have hard water, but have never seen this 6yr old unit act this way, are there any tips you can offer before calling in a repairman or replacing the unit. Advice welcome, --Phil
Ther is a hose which goes from the left hand side water chamber to the sump, this hose gets blocked and not enough water fills into the machine. Remove the left hand side panel of the dishwasher to access the chamber and hose, remove, clean & refit the hose. good luck.if any parts are required a good company i have dealt eith before is
http://www.candmdomesticappliances.co.uk
Posted on Oct 03, 2009
  • 725 Answers
Hi Phil, First I would check you drain ... Make sure it is clean, clear and drains fast...if you have a garbage disposal make sure it is also clean...also check that the drain hose is above the bottom of the sink... hope this helps you...
Posted on Sep 29, 2009
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 13, 2011 | Bosch Dishwashers
Not washing properly, it's leaving residue on the plates and glasses
Hi
Daniel
Feb 09, 2011 | Dishwashers
I am getting a lot of soap residue left on my clean dinnerware and glasses, like a dry soap residue. what can I do to fix that problem?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 12, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishes do not rinse properly--despite rinse
run some calcium lime and scale remover throught the unit on an empty wash cycle just to get rid of any build up that may be there.
turn the rinse aid down to about half way.
also check the phosphours content of you washing agent.
there is a lot of factor involved with leaving film on the dishes, it could also be residual soap content that is sticking to your dishes.
reduce the amount of soap a little.does not matter if it is liquid or powder.
once every three months you need to run cleaner through the machine.
last thing but very important make sure the incoming water temp i no lowe rthan 120 degrees.
Jun 09, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
Extra suds due to liquid soap in the machine overflowing. How do I drain it?
This is strange. Are you using an electric dishwasher liquid soap, OR are you using a dish soap that you manually use to wash dishes?
REGULAR dish soap liquid that is not specifically made for dishwashers creates a foamy suds with lots of bubbles that will in fact bubble out of your dishwasher. on the other hand. Electric Dishwasher detergent will NOT create foamy suds with lots of bubbles.
Switch your soap. The next cycle any residue suds or soap will be gone as long as you use the proper liquid detergent. I would also recommend using a rinse agent which further helps break down and rinse off residue.
Mar 18, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Bad smell on dried dishes after being washed.Stale water smell.
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Aug 20, 2008 | Siemens 24 in. SL84A305UC Built-in...
Dishes have soap residue despite using rinse aid. Machine is quite abrasive on coffee mugs etc. Unit is Fisher & Paykel DD605SS
use less soap.....excess soap in the rinse cycle will not allow the dishes to rinse properly causing white etching on the glasses and the dishes will have that gritty feeling
Aug 02, 2008 | Dishwashers
Bosch SHV68 Built-in Dishwasher Logo
159 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
