Question about Whirlpool LHW0050PQ Front Load Washer
Not spin i have kenmore elite washingmachine it doesnt spin at the end what i have to do.
  • 121 Answers
Check the brushes on the motor it sounds like they need replaced
Posted on Mar 03, 2008
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Maytage neptune front loading washingmachine, display is flashing "nd" can you tell me what that means? I cannot find my owner's manual
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.##@@@@
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
Kenmore washingmachine motor starts clicking when it starts spinning.what causes the clicking sound?
DOes it hesitate to rotate the drum at full speed?, If not, the dog gears inside the shaft may be worn and not grabbing at full engagement
Jan 25, 2010 | Kenmore Washing Machines
Kenmore f l washingmachine 110.46472501 leak from dispenser
This is joyce
is dispenser in properly, remove and put back in. sometimes the peice that is seperating the solid from liquid is in the way and causes water to come out top.
also water pressure has a lot to do with this. has this changed. have you removed filter?
Feb 06, 2009 | Kenmore Elite 45986 Front Load Washer
Try this first.
Washer won't drain or spin
Is the drain hose clogged, or the end of the drain hose
more than 96" (2.4
m) above the floor?
Is your voltage low?
Check electrical source or call electrician. Do not use an
extension cord.
Is the "SUD" routine active?
Cycle will complete once extra suds are removed.
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Timer kenmore elite 110.20952992
its needs the timer if it doesnt have the small white piggy back timer motor
Oct 22, 2008 | Kenmore Elite 45986 Front Load Washer
Check out the drain system. It could be something as simple as a pinched drain hose or a cloged pump.The trouble shooting sheet is behind the kickplate or under the top. This will walk you through the proublem.
Dec 07, 2007 | Whirlpool LHW0050PQ Front Load Washer
It sound like a motor or a belt issue. Open the machine and look for belt's condition and does the motor spins. Good luck!
Aug 05, 2007 | Kenmore 23822 Top Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
