Question about Bunn 10 Cup Home Coffee Brewer
My Brunn coffee maker is leaking from the bottom also.
Every time I make a pot of coffee it leaks water all over the counter. It worked great four years before it started leaking.
    Problem Solver:
  • 4 Answers
I have the same problem and I took the coffee maker apart to find out why. The fitting for the hold in the black pastic that the water flows through to get into the stainless steel tank may not have a tight fitting with the plastic and that's where I had water leakage. I used some silicone sealant to fix the leak and the water stopped leaking!
Posted on Oct 15, 2009
I have an 8 year old and a 9 year old unit. I phoned the Bunn supplier in Canada at 1-800-263-2256 or 1-800-352-2866 in the US.
As it turns out both of these units were on recall.
Be sure to have the "Date Code" (on the bottom of the machine) and the Model number handy when you call.
They replaced the older one and are sending parts for the newer one at no charge. Shipping and handling no charge.
Good Luck!
Posted on Jan 27, 2010
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
Jan 03, 2010 | Black & Decker SpaceMaker ODC440B 12-Cup...
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
MACHINE LEAKS WATER
Turn on machine w/o water or google the company
Jun 02, 2017 | Waring Pro WC1000 Coffee Maker
My DGB-500 Cuisinart Grind & Brew coffee maker leaks coffee
I found out that internally the water line that comes off of the heating element is made of a rubber/silicon material. The heating element is so hot that it scorches or dryrots the tube and it cracks causeing leaking. Sometimes it comes pouring out and other times it just is enough to make it a pain. I have taken the time to get my specialized screwdriver set and take off the bottom of the pot, but have not been able to find a replacement tube for it. (They also made the tube so that you dont have enough to cut the broken end off and put it back on and if you COULD do it, they also put an "X" in the original tube so if you cut it and try to put it on you cannot push it on far enough. Other than this, it was a great coffee brewer for me for the past four years. (Put baking soda and water paste on the coffee stain if you have formica counters. A few times of doing that and the stain will come clean)
Apr 11, 2009 | Cuisinart DCC-1200 Coffee Maker
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
LEAKING WATER
I had the same with a Saeco it was caused by a leaky boiler, after replacement, it was fine...
Aug 08, 2006 | Waring Pro WC1000 Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
864 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
