Question about Canon PIXMA MP830 All-In-One InkJet Printer
After replacing my MP830 ink cartridges, when printing a document not all the lines will print. This is random.
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
Posted on May 03, 2008
rhoncruz
  • 134 Answers
SOURCE: #5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Posted on Dec 02, 2008
  • 11 Answers
SOURCE: CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
Posted on Mar 25, 2009
komguy
  • 2306 Answers
SOURCE: Leaking Ink Cartridge
You need a shop to clean the extra ink that's coming up on the rollers and install a mylar strip to prevent that in the future. It's the waste ink being forced up thru the exit rollers and getting on the prints.
Posted on Sep 10, 2009
SOURCE: Canon Pixma MP610 will not print black ink. Page
kkdlist.wordpress.com/2010/07/01/14/
Posted on Aug 02, 2010
Canon mp830 has a 6A00 error code
Do a random internet search type in canon mp830 error code 6A00
to see whatt that code means
Jan 21, 2013 | Canon MP830 All-In-One Printer
Color printing
The printhead has either become too clogged to flush out with with the internal cleaning operation (which uses a LOT of ink), OR, the nozzles are not firing. If after several cleaning operations there is still no significant improvement, you will need to replace the print head. I see this frequently with Canon and Epson, and Brother inkjet printers. Usually, it is due to leaving the printer idle for too long, or removing a cartridge and not replacing it right away. The air gets to the residual puddle of ink in the head and dries it. Also, using compatible or refilled cartridges can risk clogging because the ink formula is not an exact copy of the genuine Canon formula. I recommend using only new Canon carts for replacement, and do not mix Canon with non-Canon carts.
You can find the replacement print head by Google searching "MP830 print head". Prices can vary from around $70 - $90. Changing it out is fairly simple. You only need to lift a lever that holds the head in place. Make certain that it is squarely seated, and then run a few pages of a color document, or do a couple of standard cleaning operations to "prime" the head.
Make sure the hed is NEW and not used or "refurbished". Here is one source on eBay that sells it for $78.00:
http://compare.ebay.com/like/330643273134?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
Nov 27, 2011 | Canon MP830 All-In-One Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Read fax in memory MP830
it won't print faxes if ink is too low so it stores them until you replace the low cartridge or cartridges. Don't know if you can transfer to computer. Do it the other way around and go to www.myfax.com I did and I love it.
Feb 24, 2009 | Canon MP830 All-In-One Printer
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
In Use/Memory FAX after changing ink cartridge
I had the same problem - it would not print the faxes as the machine would not recognize the generic cartridge - I had to get the official Canon cartridge to get the faxes to print out of memory.
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
24 people viewed this question
old marine
old marine
