Question about HP OfficeJet 6210 All-In-One InkJet Printer
My printer isn't scanning anymore. It says "No Scan Options". Any suggestions?
SOURCE: scanning
Many issues are caused when the HP All-in-One is connected to the computer using a USB cable before the HP All-in-One software is installed on the computer. If you connected the HP All-in-One to your computer before the software installation screen prompts you to do so, you must follow these steps: Troubleshooting common setup issues 1. Disconnect the USB cable from the computer. 2. Uninstall the software (if you have already installed it). 3. Restart your computer. 4. Turn off the HP All-in-One, wait one minute, then restart it. 5. Reinstall the HP All-in-One software. CAUTION: Do not connect the USB cable to the computer until prompted by the software installation screen.
Posted on Aug 19, 2007
SOURCE: Printer Won't Scan
I cant scan it says refer to documentation to troubleshoot. How do I fix this. Ishala
Posted on Nov 25, 2008
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
  • 489 Answers
SOURCE: c7280 hp printer won't scan, it says
First, make sure the HP Digital Imagin Monitor is running on your computer. Start it if it is not currently running. Open HP Soluction Center and select your printer (if there are multiple printers listed) and click on Settings. Click Scan Settings and Preferences. Click Scan To... Setup. Click on Destination List. Make sure that the scan destinations you want are populated in the right-hand list box. If the destination list is already populated, you will need to uninstall and reinstall the software.
Posted on Jul 10, 2009
MUKHTAR
  • 2022 Answers
SOURCE: My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 23, 2010
I have a canon MG5220 printer and unable to scan properly the messages I receive are saying Scanner turned off, disconnected from LAN, code 2,145,50. Printing pictures and all other printing jobs work...
Regarding the Cannon scanner error 2145,50. I note you have tried to fix this, but failed. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it.
I know, I had that problem. I am a retired elctronics design engineer.
Mar 07, 2011 | Canon Pixma MG5220 InkJet Printer
All of a sudden my printer won't scan anymore. It says no scanner options. Is there free updates to solve this problem. I have always been able to scan until recently.
While computer is on, Disconnect the usb cable(listen for the disconnect beep beep), Do a Full Restart the computer. Then reconnect the usb cable into a different USB port on the rear of the computer (wait a few minutes), then try the scanner options again. Sometimes thats all it takes.
Aug 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Had been scanning pictures into computer and now i
First let us remove the No Scan Option.
First try to Scan from HP director or HP Solution Center.
If it is scanning, perform the steps given below to resolve the issue.
Open HP solution center/HP Director:
Click on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
Jun 02, 2010 | HP Photosmart 3210 All-In-One InkJet...
Push SCAN on my HP6310 and get no scan options
You need scan software running on your computer. It won't scan unless it knows how to scan and where to send the scanned image. The scan options will be on your computer.
Oct 28, 2009 | HP Officejet 6310 All-In-One InkJet...
My Officejet Pro 8500 won't scan, although it did fine originally
It won't scan unless the HP scanning software is loaded and running on your PC, it needs to know where and how to scan, which is the scan options. It will scan and make a copy if you press copy, but it won't scan when you press scan unless that software is running.
Sep 10, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
My HP 5610 all-in-one gives me an error message when I try to use the scanner option.It says, "No scan options: Refer to device documentation to troubleshoot." what do I do if I don't have my...
oh This is a simple solution open up the hp solution centre icon or the hp director icon whichever your printer software has on the computer.
Then click on settings.
point to scan settings and click on scan to setup and on all the items on the left hand side select them and move them to the right hand side and click on the ok button or the update the device button and you will not face this issue anymore.
your printer software should be installed so that you dont get this error message anymore
Jun 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Aug 31, 2008 | HP Photosmart C6280 Printer
HP Photosmart C5280 Printer -scanning
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Jul 20, 2008 | HP Photosmart C5280 Printer
HP 5610
If you have windows vista and it comes up with the "no scan options" don't press the button on the printer, go to "start" then "accessories" then "paint". This will open up the windows paint program. Go to "File" then click on "From scanner or printer". It will then scan the document, no more problems! Happy scanning
Oct 27, 2007 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
