Question about Gyration GP9110-001 Wireless Keyboard
Gyration keyboard does not type or respond to anything. Green light does light up on keyboard when typing but not on Gyration USB device.
5 Suggested Answers
SOURCE: Keyboard wont respond
Often this is simply because the radio link between the receiver and the mouse/keyboard has been broken. Some possible reasons for this are: flat batteries, insertion of new batteries, connector to the computer removed, etc.
In the first instance, you should restore the Logitech devices to a defined status (reset). To reset the device:
Remove the batteries from the mouse/keyboard for approximately ½ hour.
Press and hold the "Connect" button on the receiver for 15-20 seconds. Make sure that the receiver is connected, the PC is switched on and that there are no batteries in the devices. After resetting, insert new batteries and restore the connection as follows:
  1. Press and hold the "Connect" button on the receiver for 1-2 seconds.
  2. Then immediately press the "Connect" button on the bottom of the mouse (locate this button before you start, all cordless mice have a "Connect" button)
  3. Move the mouse around to check that the connection is working correctly
  4. Press and hold the "Connect" button on the receiver again for 1-2 seconds.
  5. Then immediately press the "Connect" button on the bottom of the keyboard (locate this button before you start, all cordless keyboards have a "Connect" button)
  6. Use the keyboard to check that the connection is working correctly
  7. Both devices should now be working correctly
If one or both of these devices is still not working, try them on another compatible PC system to ensure that the fault does not lie with your PC system.
Posted on Jan 14, 2008
SOURCE: Gyration GP9110-001 Wireless Keyboard
if its an old model like mine and i think it is . it should have a little box with an antenna with 3 foot cable usb . no software needed . if it is newer model it would have a little usb dongle
Posted on Oct 06, 2008
SOURCE: Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Posted on Oct 30, 2008
SOURCE: My Acer Keyboard wont respond when i press the key's
A few days ago my acer laptop aspire 1640z , began to behave slower than usual when typing on the keyboard. At first I thought it was a virus, I did all the necessary scans and found none.
I then thought it might be the Keyboard driver, but it wasn’t.
I went into safe mode by keeping F8 down when you start the computer and select the directory service restore mode, which resets certain applications back to its original state. I found that my internet AOL connection and explore and fire fox would not connect to the net. Make sure you have a disk for AOL or setup file for fire fox saved, to reinstall the software. This seemed to work a bit but by accident, I remove the battery from my laptop and kept the power cord connect and Wow! it works even faster than before.
I have also notice that my battery does not hold a charge anymore. My theory is that because the battery is in critical status when connected to laptop…. (Even though the power cord is connected), the computer thinks that its going to run out of power and wants to go into hibernation mode which slows everything down including typing on the keyboard.
So before you try the safe mode option, remove the battery and use only the power cord cable and see if this solves the problem. Mine is running fine again ,but when I put battery back it slows down again. I read on the net its affecting only Acer Laptops, probably because the way the power settings software is set up for the Acers.
Stephen P
Posted on Aug 31, 2009
How do I connect the keyboard? it goes into the USB port but does not respond or type letters on screen.
normally when you attack a usb device the computer will automatically look for drivers for that machine. What you describe indicates a missing driver for what is attached to the usb lead. Go start ---click on devices click on the new device- double click on the device and then click on properties tab across to drivers and open click on install driver.
Oct 23, 2014 | Tablets & eReaders
Gyration GC15CK keyboard meia buttons do not respond. i.e., Mute,Volume,Mail, etc.
You need to find the HomePage and download the driver for the keyboard and download it.
Oct 18, 2009 | Gyration GP9110-001 Wireless Keyboard
How to install Movea gyration wireles keyboard
This is what I read on the net. May help you too/
"Gyration Wireless Keyboard and MouseFor a few months now I've been happily using a Gyration Wireless Keyboard and Mouse for my Windows Media Center. I've been extremely happy with this combo. The mouse can be used without needing a table or surface (you just wave it in the air). It takes a while to get used to this, but once you do then you are free to walk around etc while you control the mouse. The mouse comes with a charging station and also has an optical sensor so that I can be used as a regular mouse.
They keyboard is very small, and is running on it's original set of batteries. It's perfect for MCE as I can easily hide it. Another bonus is that the keyboard requires no drivers and works on the BIOS screen in case you need to make any tweaks etc.
A few weeks ago, my mouse flaked out though. On Monday I finally got around to calling them. The support experience was fantastic. I got a human on the first ring and he told me to send it back to them (no need to find my receipt or anything). Today I got my replacement (total of 4 day turnaround). Now that's great service!"
Try using it. It really may not require a CD to install. Just plug it in and off you go. All the best.
Aug 20, 2009 | Gyration Computers & Internet
How do i set up my gyration wireless mouse ???
The Gyration air mouse is easy to use & install. Just plug in the USB receiver into available USB port, slide the Air mouse switch to on, press the connect button on the receiver & air mouse, your computer will automatically detect & install the device. “there are no drivers to manually install”
Please let us know if that was helpful enough.
Thanks
Shiv.
Aug 12, 2009 | RCA Gyration Wireless Mouse
Gyration wireless keyboard not working
did you set this up with your regular mouse?
Mar 31, 2009 | Gyration GP9110-001 Wireless Keyboard
All of a sudden my gyration wireless keyboard won't work
LOOK IN THE CONTROL PANAL LOOK IN THE FOLLOWING FOLDERS, DEVICE MANAGER,NETWORKING AND SHARING, PROBLEMS & REPORTS, SYNC CENTER,
CHECK THE FIREWALL AND OR THE SECURITY CENTER, THE SECURITY CENTER MAY OFF BLOCK THE COMMUNICATION TO THE REST OF THE COMPUTER SOIT STOPPED WORKING
LOOKING FOR ANY TYPES OF MARKS, GREEN MARK IS OKAY AND WORKING FINE.
WHEN IN THE DEVICE MANAGE CHECK FOR UPDATES
ROD THE CANDYMANGANDY
Feb 12, 2009 | Gyration GP9110-001 Wireless Keyboard
Keyboard not responding
Please send deatils:
Operating system. Brand, USB pr PS2,
You can try following before sending details.
1. Right click my computer then properties then hard ware. then device manager. See keyboard is listed against + sign, if yes expand it and see "Standard101/102-key or standard Microsoft manual PS/2 keyboard. If Yes the right click on it and update driver. If problem is not solved click on properties ans see device status " device is working properly. Further try to uninstall and remove USB or PS/2 cable and reinstall . Reboot the system.
Nov 11, 2008 | Logitech 967437-0403 Keyboard
you can go to gizmo.cafe.com and you should be able to help you out there they should have the user manuals there for almost any wireless keyboard
Aug 12, 2008 | Gyration GP9110-001 Wireless Keyboard
Keyboard won't respond
It is odd that it will type before you log in, but not after.
If you have access to a USB desktop keyboard try using that to see if it works after windows has been logged in.
I'd also check the Device Manager. You can get their by clicking on the start button, then click run. After the box pops up type "devmgmt.msc" into it. This will pop up a box that shows you all the devices in your computer. When this is open find the keyboard section and click on the ' + ' . After the keyboard section is expanded look to see if anything under their has a red ' x ' or a yellow exclamation point through it. If it has one of these symbols, double click on it and try to enable the device. Let me know if this doesn't do anything, there may be 1 or 2 more things to try.
Nov 14, 2007 | Computers & Internet
Gyration GP9110-001 Wireless Keyboard Logo
277 people viewed this question
Top Gyration Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
solver2010
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
