Question about Garden
My ride on Craftsman mower will not start. The meters displays 0 volts when I turn the ignition on. I bought a new battery the same problem exists. How do I troubleshoot this?
    Problem Solver:
  • 13 Answers
You are probably looking at the amp meter if its on the mower . I f you have a new battery its not likely the battery. Have you checked the seat sw. and clutch pedal? Really need more info
Posted on Sep 29, 2009
**Help** I have a Sears Craftsman 18hp Briggs/Stratton riding tractor, about 10 years old. Just put a new battery in last week. Went to start this morning and battery was dead. The red cable that goes to...
Yes it very well could be the starter solenoid, with a digital volt/ ohm meter and the battery disconnected place the positive lead on the positive test lead . With the meter on ohms take the negative lead and touch the frame or engine . This will confirm weather or not you have a short to frame. If the meter reads 0.00 disconnect the starter from the system by removing the positive and ignition wires from th starter . Now individualy test each wire removed from the starter in the same process as above if ohm meter read ol ( over limit) the starter would be the best place to start. If the meter reads 0.00 would suggest there are other issues in the circuit and the starter may not be at fault.
Oct 14, 2013 | Craftsman 42" Briggs Stratton 20 hp Gas...
Craftsman lawn mower 917270810 will not start
When the ignition key is turned to the start position you should have a 12 volt supply to the low tention wire at the solinoid, if not you need to check if there is a 12 volt supply to the back of the ignition switch, if not there is a break in the wiring to one of these components, also check that there is a good eart to the chassis from the black battary leed.
Jul 07, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 6 year old Craftsman rider, model 27363 w/18.5 HP Briggs engine and 42'' deck. I tried to start but nothing - no click, ammeter doesn't move, hour meter doesn't run. Checked battery, have 12.8...
The start circuit usually only goes through the clutch/brake switch, and the clutch switch. That way it won't start if the clutch isn't depessed (brake on) and the mower deck turned off. You can test for voltage on the s terminal (start) on your switch. then for 12V+ at the clutch brake switch, then at the clutch switch, finally at the solonoid. The seat switch usually only kills the ignition if you have the PTO engaged, and you leave the seat.
Jul 26, 2010 | Craftsman Garden
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
Mower sometimes will not start. Has new battery
You have to use a volt meter and test the ignition circuit to find out where the voltage stops. If you have 12 volts going in to and out of the switch, then switch is good
Nov 02, 2009 | Craftsman Garden
PTO will not engage blades on riding mower. The
Using a test light or volt meter, check to see if you are getting a full 12 volts at the connector where the PTO plugs in. If no voltage present, locate the fuse for the PTO and check it, also check the PTO switch to see if it is working. You can turn on the ignition switch to the run position, don't start the engine, and turn the PTO switch on and off several times listening for a clicking sound. If you hear it clicking, have someone sit in the seat and start up the engine, while it is running, observe the PTO clutch and see if it spins when turned on and if the belt turns with it. If none of this works, post a follow up and include your Craftsman Model number. I will look it up and see if I can find anything else we might be missing
Sep 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
It won't start
do you have power to the solenoid?? with the key on there should be 12 volts on one side of the solenoid then when you turn the key to start it should send 12 volts out the other side to the starter
Apr 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
216 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
