water leak at rear of filter at hose connections. will old filter cause this to clog and force water out of the connection fittings at the clear plastic water lines
it sounds like the filter housing could have a crack in it, but It could potentially be a leaking line. In the event the old filter where clogged to the extreme, you'd simply have little or no water flow, not enough pressure to cause a leak though. I've seen these housings damaged by customers forcing the filters in or out in ways never intended.
To check the lines are secure/not leaking...
**FIRST unplug the unit from the wall and turn off the water supply**
either go thru the front by removing the toe panel/kick plate grill, or go thru the back panel, you'll still need to remove the grill at the front though. the 2 screws securing the filter housing to the fridge are at the front behind that grill. (if your lines are long enough -they usually aren't- you can undo the screws and pull the housing out to work on it easier/unimpeded). remove the 2 lines to the filter housing carefully(when removing these you simply push the tab surrounding the line "in" or "down" and pull out the line) and inspect them at the ends where the "seat" in the fitting/"O" ring within the housing. with a razor blade or sharp utility knife, cut off a small amount to insure a clean fitting when re-installing the lines into the housing (simply push them in the way they came out, until they bottom out and you can't pull them back out). once that's done you can turn the water back on, plug the unit in, and check for leaks. Is it actually the lines, or the housing itself ?
I've seen this a few times. the complete housing can be replaced and it isn't that difficult. First verify it is leaking behind the filter at the housing, I could try and help further. the housing is # 2186443 if youneed it.
No to your question . Your filter is probably cracked at the portion inserted into the housing first . Replaceing the filter will probably stop the leak .
On my side by side built in refrigerator, the digital controls are blinking and the refrigerator...
(More)
On my side by side built in refrigerator, the digital controls are blinking and the refrigerator doesn't seem to be working.
my kitchenaid just stopped making ice. I believe that the ice maker is frozen, is this something I...
(More)
my kitchenaid just stopped making ice. I believe that the ice maker is frozen, is this something I can fix myself?
