Question about THQ The Lawnmower Man
My Toro LX500 Tractor steering is messed up, the steering wheel spins freely, not turning the tires. Gear looks a little worn. Is there a bushing around that shaft too, seems sloopy
I have just had the same problem.. the steering shaft is held in place only by the deck sheet metal, which has worn & is now too big to hold the shaft in the correct position, funny how a $2 bearing would have prevented this from ruining an otherwise great mower. I'm going to take mine to a mower shop & hopefully they can install a bearing there.
Posted on Jun 10, 2010
Steering on my Toro lx420 is loose. It takes numerous turns of the wheel to engage gear. I just replaced the gear and pinion but there is still alot of play between the pinion and gear.
Steering shaft has oil-lite bushing that wears = replace bushing. FWI, you posted in the wrong section--this is for cars and trucks.
Jul 23, 2015 | Cars & Trucks
Toro 57360 lawn tractor transmission problems
It might have run out lube and seized pull out and check.
Sep 12, 2014 | Toro Garden
MTD tractor is "jumping teeth" on the drive shaft of steering as it doesn't mesh together smoothly either due to worn gears or improper spacing. Wheel thus spins with little catch in the gears to allow...
There could be several things going on with the steering gear. First check and make sure there is no debris or rocks caught in the gear. Then check the up and down motion of the steering wheel, it could need some shims under the shaft due to wear. Also check and make sure the bolt on the cross member is tight as well as the steering gear half moon. Another good resource for steering wheel shaft service is to go to MTD website ( service,mtdproducts.com/Training_Education/769-00947_SM_600_Series_Box_Steering_Shaft,PDF) This can be found at the MTD website under training and education and has a step by step instruction on servicing the steering system. This should get you rolling and cutting again.
Oct 30, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Cub cadet lawn mower steering wheel will not turn all the way to the right. It turns all the way to the left, but not the right. Checked the teeth on the fan gear, all are okay. what next?
Even though the teeth on the fan gear are ok, they may have skipped past each other a few teeth. My tractor has a bushing that the end of the steering rod passed through before attaching to the fan gear. The bearing was worn, allowing the steering rod to move, and the fan gear would then to lose it's grip from time to time, eventually making my tractor perform much like yours. See if you can replace that bushing, your issue should be solved.
Mar 17, 2013 | Cub Cadet 50 In RZT Deck Belt 75404044
What is the foot pounds for the front wheel bearings on a 1995 chrysler cirrus
Hello, If you Chrysler has replaceable wheel bearings and seal. This is the way it goes---pack the wheel bearing with new grease-install the bearing in the wheel nub--install new back wheel seal--coat the axle shaft with grease lightly, thing coat-----install wheel hub on to axle shaft...be careful here don't damage the rear hub seal------------insert front race washer---install axle shaft nut--tighten nut down wheel nut until it is firm with water pump pliers----spin the hub/with tire mounted.
(the wheel and hub will turn but not freely)----take the pliers and back off the axle nut 1/4 turn----now spin the wheel and axle hub, it should spin freely---now if doesn't spin freely---back off the axle nut about 1/16 or 1/32 (or just a little bit)-----now, spin the wheel and hub and if turn freely------------Now grab the top of the wheel/tire and move it back and forth.-----if there is some movement ---try tighten the axle nut just a little little bit, unit the one can barely feel some little movement in the wheel/tire and hub.-----------Now, spin the wheel/tire and hub and it should also turn freely.
If it does----install new and correct size of cotter pin and bent the ends around the axle nut.----
coat the inside of the hub cup with grease. Now, use an rubber or plastic hammer to install the cup on the wheel/tire hub. You are finished with one wheel bearing maintenance. Now do the other side.
I really don't know if you Chrysler Cirrus has replaceable wheel bearing. All the auto/trucks have replaceable hubs, that means that the replacement is total hub with axle shaft, sealed bearings, and seals. This is bolt to each wheel steering hub. This work to remove these one unit hubs.
Four bolts hold the axle hub to the steering hub. Hear is the problem!! it has rusted to the steering hub. Also, these hubs cost more than replacing bearings, races, seals to cool turn of $180 to $250+ I wish you luck in your replacement of wheel bearing on your Chrysler. GB..stewbison
Sep 24, 2011 | Chrysler Cirrus Cars & Trucks
Steering wheel turns freely but does not move wheels
Follow the steering column down to the gearbox. You will see a "knuckle" that the arm goes into. It may possibly have a "donut" that looks like it's made of a tire - if not it will go into a metal flange that transfers movement to the gearbox.this is where you need to look closely and have a helper move the steering wheel as you are looking. The donut or the flange has broken and you will need to replace the part there.
Nov 22, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Turns left sharply, barely turne right
The problem is either that there isn't enough range on the steering gear in the right direction, enough length on the steering drive rod (going to one front wheel), or a bent tierod (connecting the 2 front wheels) or worn tierod bushings.
Most likely is the tierod. I do not like how these are designed so for my own tractors I make one using tierod ends available from tractor supply company, grade 8 bolts and steel tube with a 3/4" inside diameter. A bit of measuring and welding later the steering is better than new.
May 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
1994 LHS STEERING BROKE - WHEEL FREELY SPINS
First thing I would check is the inner tie rod bushing, common failure on Chrysler products.
Feb 09, 2009 | 1994 Chrysler LHS
THQ The Lawnmower Man Logo
995 people viewed this question
Top THQ Video Game Consoles & Games Experts
James Wishart
Sandeep Kumar
Edward Talavera
Edward Talavera
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
