Question about Sony Cyber-shot DSC-W55 Digital Camera
When the camera is turned on, the lcd screen is barely lit
Acer aspire one screen barely displayed
There are two causes, the inverter board, " just under the LCD screen" more likely, or the backlight behind the display, "less likely"
Apr 18, 2012 | Acer Aspire One PC Notebook
In my w180 image is clear and bright in the LCD screen but when i downloaded the images to my PC it shows poor lighting and dark images pls help me
The lcd screen on your camera is back-lit and shows a brighter picture than the one you actually take. If you can turn down the screen brightness that may help. You could also raise the "exposure compensation" setting and experiment until you find a setting you like.
Oct 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
EX-Z750 LCD screen dimmed, then black
on the bottom of your camera by the battery theres a little hole sizes of a niddle,get a niddle and stick it in there press down and reset the camera to factory settings ,make sure the camrea is on when you press the reset.please leave a comment,vote,note.thankyou
Sep 13, 2009 | Casio Exilim EX-Z750 Digital Camera
Dark screen when I turn on the camera and take pictures.
It looks like the LCD backlight malfunction. Check the backlight voltage, if you have the voltage there, you need to replace the LCD unit, otherwise the main board is defective.
Aug 03, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Display screen is black
I've been told it's the LCD Screen. I have a new LCD screen but now can not find any instructions to change it out. It is not in the manual. I wish I could help. And this sight appears to be complete useless.
Jun 24, 2009 | Nikon Coolpix S550 Digital Camera
Camera monitor very light
The LCD Monitor Brightness has a range of -5 to +5.
Rotate the mode dial to Setup. Turn on your camera.
Go into the Setup Menu, then Custom, then select LCD Brightness. Make adjustments as needed.
Let me know if this fixes the LCD monitor. Thank you, Binary Bob
Nov 10, 2008 | Vivitar ViviCam 5386 Digital Camera
Takes photo but black screen
Are you sure the camera is set so the LCD (the screen) is lit? Check if the EVF (electronic viewfinder) is working. At the right of the screen, you will find two buttons on top of each other. Press the top one once or twice and see what it does.
Jun 02, 2008 | Fuji FinePix S7000 Digital Camera
LCD Screen dead
This may be a dumb idea... but did you accidentally turn the screen off? Don't ask how I know this...
Dec 26, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Black screen Kodak EasyShare C653 Digital Camera
probably you unable the lcd display function, try hit |0|i button, its upper menu in you camera, also you could try hitting menu button, if lcd comes back and you can see menu, then is not a camera problem, it's a configuration. i recomend you read quick starting guide.
gretts, a.
Oct 16, 2007 | Kodak EasyShare C653 Digital Camera
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
Jan 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
