Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Model 139.53930DM I adjusted the chain and now door only goes up 12" (too tight?)
    President:
  • 3,197 Answers
The chain might be to tight but I think you should check for broken door springs or a bad drive gear. The gear is white nylon and is just in front of the motor. The chain should sag just a bit.
Posted on Sep 28, 2009
Chain tight against stop bolt and will not close
Take the stop bolt out and run the garage door down.
Adjust your up travel limit so it spent open up so far.
Replace the stop bolt and nut.
Aug 25, 2014 | Sears Craftsman LiftMaster Chamberlain...
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Chain broke, I reconnected the chain, udjusted it so it was tight and now the short side is loose hanging low and the longer side from gear to gear is extremely tight, under tension. HOW DO I REMOVE THE...
Release the door from the opener by pulling down on the rope. It will be very hard to pull. This should release the tension on the chain but I think you need professional help with this opener. It sounds like it is badly out of adjustment. The chain coming off is an indication of a worn bearing that will have to be replaced.
Jun 06, 2011 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener chain out of sync with door
There are two white screws on the sides that adjust the limits. Adjust the "down" screw less. You should have to turn the screw 4 full turns for eight inches. After you make this adjustment, test it without the door being hooked up to prevent damage to the door or opener if it tries to close too far.
Feb 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Sears opener wont open or close more than 12 inches
You may have put the chain back on out of "sync" with in internal up and down stops. You may have to take the chain off the motor sprocket and run the motor to make sure it is stopped in the down position ( watch the rotation of the sprocket to determine up or down position) When the motor is stopped in the down position put the chain back on with the chain Carriage in the down position. Then you can fine tune the up and down stop positions with the adjustment screws on the side.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't shut after changing gears
if you changed gears, you may have chain out of sync. read instructions with gear kit on how to sync chain.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
229 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
