I have just bought a bush hdlcd 100hz tv the info on the telly screen says displaying 1080p@50hz why 50 hz shouldnt it be 100hz
  • 8,457 Answers
U in EU right?Some tv buy out of the countries or imported needed transformer voltage rectulator so step up or down the voltages.
Posted on Sep 28, 2009
What is the Hz for the Panasonic 42" TH-42A400Z ?
This tv was intended to be used in New Zealand. It is rated 50/60 Hertz. Just google the user manual and you can see that the retailer told you a fib.
Regards,
Joe Van Buren
Aug 02, 2014 | Panasonic VIERA Televison & Video
Tip
How to set 100hz or Motionflow/Trumotion Effect on Panasonic 42X20 Plasma or...
To those who want to have the Motionflow/Trumotion effect on this Plasma Flat Panel TV or similar models, do the following:
1. Set your media player / source (PS3, Xbox 360, Western Digital Media player, Apple TV, etc) at 720p@50hz / 1080i@50hz / 1080p@50hz.
Note: not all player supports 50hz read your source manual if your source/media player can support 50hz
2. Go to the TV's menu and select Setup
3. Select Other Settings
4. You will be able to change refresh rate to 100hz for a Motionflow/Trumotion effect that they have on LCD/LED (if you don't see the 100hz setting that means your source is at 60hz not 50hz)
Note: 100hz refresh rate is different from 600hz subfield drive.
on Mar 26, 2011 | Televison & Video
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
Display in top right corner says 1080i and 50hz . can i change to 1080p and 100hz as tv supports this
You cannot change this. The program sets the TV. The display only informs you what the program you're watching was recorded in.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a samsung 6 series led tv which says it plays at 100hz, however on screen it only ever says its playing at 50Hz. How do i get it to run at 100Hz?
120 hz and 60 hz any ways heres the thing it is running in a 120hz but its always going to say 60hz because its not a true 120hz your tv is upscaling it to 120hz its called auto motion plus you can adjust it under settings but it will always say 60 hz never 120hz cause it dosent do it true you can call samsung or read the forums at cnet.com i have the same t.v. just the 46 in samsung and sony are very shady in the way they word things
Jan 06, 2011 | Televison & Video
I have an 100hz tv but its saying its playing in 50hz how do i change please
if in usa most tv 120 hz if eu. they play on 60hz is it working
Jun 22, 2010 | Televison & Video
Good evening, I've gone through the manual and I can't get my TV to show 100hz (always 50hz), also on some channels I cannot get the picture to fit the screen (it's 32''). Any help would be greatly...
Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
Mar 15, 2010 | Televison & Video
I have set my LG 47LH4000 to trumotion 100hz but when you press the ok button when watching it says 1080i 50hz should be 1080p
All TV signals, including SKY, are transmitted at 1080i and 50hz. The only sources for 1080p are Blu Ray, XBox or PS3
Mar 09, 2010 | LG 47LH40 47 in. LCD HDTV
How do change tv to run on 100hz from 50hz?
MrMark - Samantha is not talking about power, she's talking about the screen refresh rate. Quick to belittle...and wrong.
Jan 30, 2009 | Televison & Video
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
