Question about Whirlpool Duet GHW9150P Front Load Washer
Have to replace the shocks and the way the tech told isn't right - is there somwhere i can go to find out how to unlock the old ones and get them out?
    Genius:
  • Whirlpool Master
  • 1,460 Answers
You could try utube video
Posted on Sep 28, 2009
How do I run F8 on a minolta Di2010?
go in service mode (utility/counter -> stop - 0 - 0 -stop - 0 - 1 )
go in tech choice, and there you find somwhere f8, and press start. wait about 5 minuts. when start button turn blue reset the mashine.
remember never to stop the f8 procedure.
Jan 20, 2015 | Konica Minolta Office Equipment & Supplies
I was told that my Toyota Highlander has leaky sway bar links that need to be replaced. Another Toyota dealer said they are fine and there isn't anything to possibly leak in a sway bar link. Not sure...
On the suspension the only thing that can leak are rack and pinion, shock asorbers,and motor mount and axle boot.there is no fluid in sway bar you need to find someone who will show you and who you trustcansmo_152.gifcansmo_153.gifcansmo_154.gif
Aug 29, 2011 | 2003 Toyota Highlander
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
I would like to check the fuses for the power passenger window side, but how can i check the without getting shocked. I know where they are located and I know it isn't the window motor and the switch...
Well try to pull the fuse and see if its burnt or not. and you will not get shocked, because its just 12V and there is no way that the fuse will shock you. just pull the one the you think its burnt and try to replace it. are all the windows out of work ?
May 21, 2011 | Ford GT Cars & Trucks
I need new shocks on my 2001 LX470. The Toyata Dealership in Longview, TX has quoted me $1618 to replace the shocks. No one else will do it because the shocks have hydraulic fluid running through them. ...
take a look at www.strutmasters.com for replacement suspension kits for that vehicle. it is going to be expensive to swap it in, but once you have that stuff taken out you won't have to fix it again and again and again.
Apr 29, 2011 | 2001 Lexus LX 470
I have a 2004 toyota tundra crewcab and when I go over a big bump it sems to bottom out. I went and had the shocks looked over and they told me that they were fine. I noticed that the shocks only have...
You may have a different suspenion pkg
than the other truck
You can't tell much by looking
You have to remove the shocks and
work them by hand, and then replace
if they are 5 to 6 years old and 50,000
plus miles.
Backs will last longer
Dec 19, 2010 | 2004 Toyota Tundra
Dell XPS 1330 - screen goes funky with lines memory parity error
the tech is saying that they replaced the motherboard and if they replaced it with the same model number and the manufacturer didnt fix the problem you had to begin with then the new issue is just a mirror of the old one and will require a Motherboard to fix.
Jun 22, 2009 | Dell XPS M1330 Notebook
Lg wm2010cw Washer Drum Banging and Vibrating
yes was the counter weights aka shock absorbers
Apr 16, 2009 | LG Washing Machines
1997 Isuzu Trooper alternator replacement
You'll have to rock the alternator back and forth to get the bushing that the lower bolt goes through to slide back enough for the alternator to slide out.
Oct 26, 2008 | 1997 Isuzu Trooper
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
