Question about LG DLE5977 Electric Dryer
My Hotpoint TCD970 trips the rcd socket it is plugged into. Have cleaned condenser and filter etc, sometimes it dries for a few minutes, the cuts out and won't start again - just keeps cutting out.
  • Anonymous Mar 15, 2014
    All filters cleaned and connections checked.
    Genius:
  • LG Master
  • 1,467 Answers
Try cutting off fitted plug put new one on ,,Could also be element
Posted on Sep 28, 2009
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
Hotpoint TDL 52P trips RCD at fuse box when switched on at socket
hi martin it sound like bad earth this could be anythink check the plug for loose wire check the socket for loose wires if check motor wire in the washer also check circuit board connections if all wires are ok you could have a faulty motor hope it helps
regards
shaun
Nov 14, 2011 | Washing Machines
Our hotpoint ctd40 condenser dryer aquarius trips our household rcd panel when you try to start the machine all the power lights are on and it does not blow the plug fuse. I have cleaned all the filters...
I would get an electrician to check the machine as it appears to have an earth fault on the machine wiring , This type of fault will operate the RCD quicker than the fuse will operate. I am a qualified electrician by trade.
Feb 04, 2011 | Hotpoint Dryers
I have a new (1 month old) Hotpoint Condenser Dryer (TCD980G). When it is on the drying cycle it runs for about 30 minutes and then trips the RCD circuit. I have cleaned the condenser filter and the water...
There should be no condensation present if it is a condenser dryer, this is the idea of it.
As for tripping the electrice, then it suggests to me that the steam could be the cause of the problem.
As it is a new dryer, then I would strongly advise you ring Hotpoint service, or ring the help line number in your instruction book.
You can contact them at the following address if needed.
WWW.HOTPOINTSERVICE.CO.UK
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius condenser dryer model no. TCL770 . Switches on ok and can select program etc but as soon as I try to start the program it trips the electric. Any help please as to what is causing it and...
we had this, and it turned out to be the plug getting damp at the back of the dryer due to inadequate ventilation at the back of the dryer...we pulled the dryer away from the wall slightly, allowed the plug to dry out for a few days and the problem was solved.
Feb 28, 2010 | Hotpoint Dryers
Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
I have in indesit tumble dryer model no;-IS70C.When i hit the start button the machine cuts out right away and trips the main socket RCD in my fuse box.Sometimes the machine starts and then cuts out again...
Hiya drodger, i had the same problem with my hotpoint dryer, (same company) if this is a condenser dryer make sure the drawer is collecting the water there is a small hole at the bottom of the drawer if you have a straw poke it in and clean it out, also at the back of the dryer there is a clear plastic pipe and a black one take them both off and clean them, your problem is exactly the same as mine so you will probably have to buy a new heating element (they are a lot cheaper from ebay) they are so easy to fit just 2 clips (i did it and im not dead yet!) hopefully you will then find the dryer will work perfectly, word of advice though clean the collecting drawer out at least once a month.
Hope this helps
Sep 27, 2009 | Dryers
LG DLE5977 Electric Dryer Logo
473 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
