Question about Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range
Whirlpool gas oven shows to be almost 100-degrees off, according to cheap $5 hanging oven thermometer. Months before, showed F3 error after heating recently washed pizza stone, causing lots of steam. Did I fry some electronics?
  • dallas_rat Sep 29, 2009
    Thanks, Eric.
    Yes, I found the info on how to do that, but will only compensate for up to 30-degrees (still another 70 or so off). I was curious if any part was damaged enough to cause issues or if it would indeed go bad soon.
    Are there any suggestions to replace with a better/durable sensor if I did this?
  • 999 Answers
Might have damaged the sensor. with the steam. There is a proceedure for adjusting the temperature reading but I do not think it will compensate for 100 degrees. i would replace the sensor.
Eric
Posted on Sep 29, 2009
Testimonial: "Eric was quite fast with a helpful suggestion!"
  • Eric Duda
    Eric Duda Oct 12, 2009
    All the sensrs are manufactured by the same company and repackaged fr each brand. You only have whats available n the market. sorry...Eric
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Whirlpool Accubake Wall oven, RBS305PD86 will not heat over 350
The first thing to ask yourself is "Is the thermostat accurate?"
Get an El-Cheap-O oven thermometer at the grocery store. Set your oven for any random temp, say 325. With the over thermometer HANGING FROM A RACK IN THE MIDDLE, wait until the oven light that tells you it is heating goes out, indicating that the oven is at 325. Open the door and QUICKLY read the thermometer you have hanging in there. IF the hanging thermometer and the temp displayed on the oven match within, say, 25 degrees then we have an issue. And, as you say that you have already replaced the temperature sensing element, that only leaves the control board or the upper and lower safety thermostats. Those are what we call "Snap Disc" thermostats. To see a typical snap disc thermostat, go to ApppliancePartsPros.Com or just BING (NEVER 'Google') Part Number: AP3055315. These theremostats may be opening prematurely, preventing the oven from reaching full temp. And once the oven cools, the snap disc will close again, allowing the unit to work. Kind Of. If it's not one of the safeties, the board is toast.
Nov 26, 2014 | Whirlpool Kitchen Ranges
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
I have a kenmore mark 1 oven in my apartment and the oven temperature says 1-9 instead of going in degrees such as 100, 350 etc. I am wondering which number stands for which heat?
This Conversion table is from the old Gas Mark scale
I'm thinking it should be right or at least pretty close.
You could also get a cheap ($5-7) oven thermometer from local grocery store.
Put it inside oven to check actual temp achieved.
Gas mark Fahrenheit Celsius
1⁄4 225° 107°
1⁄2 250° 121°
1 275° 135°
2 300° 149°
3 325° 163°
4 350° 177°
5 375° 191°
6 400° 204°
7 425° 218°
8 450° 232°
9 475° 246°
Apr 10, 2011 | Ovens
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
Whirlpool SF36 Gas Oven - F3 F2 ERROR above 350 degrees
Unplug the range.
The oven temperature sensor has failed and must be replaced.
Remove the racks. Remove the temperature sensor located up high on the back wall of the oven.
It is a short thin round piece of metal.
Feb 13, 2010 | Whirlpool SF369 Gas Kitchen Range
oven senor not working right . it may have carbon that need removing or it may just need changing due to breakage
Feb 13, 2010 | Whirlpool SF367 Gas Kitchen Range
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 71414 / 71419 / 71410 / 71412 Gas Kitchen Range Logo
176 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
