Question about Dell Inspiron 700M Notebook
Dell Inspiron 700m won't start
I have a Dell Inspiron 700m that was working flawlessly until this weekend. While on vacation, I had it plugged in and all programs closed. I closed the lid which usually sends it into Standby, then Hibernate. I woke up the next morning and opened the lid to the "Blue Screen of Death" and something about a memory dump. I turned it off by holding the power button down, waited, then tried to turn it back on. All I got was a short beep, then 3 beeps, 4 beeps, and 3 beeps and a black screen. It shows the battery charging if plugged in and shows the power "ring" lit up green. But it's not doing ANYTHING. Any hints on what to do next to fix it? Thank you!!
  • fratboy72 Oct 01, 2009
    leecom72 (and others),
    I received my 1gb RAM replacement card and removed the old/installed the new today. Still, same problem. 1 beep followed by 3 beeps, 4 beeps, 3 beeps and NOTHING on the screen. Ugh. Any other advice?
    Thanks again, leecom72.
    I ended up FINDING my receipt for the computer and found that I had a little over 100d left on the warranty. I chatted with Dell last night & they're sending out a tech with a new motherboard, lcd, lcd plastics and memory. Let's hope that works.
    Thanks again for all of your wisdom and help!
    Gary
  • Dell Master
  • 4,806 Answers
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Posted on Sep 28, 2009
Testimonial: "leecom72, Thank you for the prompt advice. I tried it cleaning it, but still not working. I'll try new memory (wanted to upgrade anyways). Thanks!"
  • Lee Hodgson
    Lee Hodgson Oct 01, 2009
    Hi again,
    OK, this now sounds serious beep code 3-4-3 is certainly a memory issue but it's to do with a failure finding video read only memory.
    Removing and replacing the RAM usually can sort this problem out but unfortunately not in your case.
    Try this to see if it works on your machine >>>>>
    Remove the battery and the power supply. Hold down the on/off button for around 30 seconds. Plug in the AC power only and turn the machine on. Keep your fingers crossed on this one.
    If you have to keep on repeating the process until the monitor displays.
    I now recommend that you contact Dell because this is GPU (graphics processing unit) problem to do with nVidia graphics cards running too hot so communication between the video memory and the BIOS has failed.
    Dell know about this issue so if it's still under warranty or you have extended the warranty the please take advantage of that because even if you get the laptop to display the problem will re-occur.
    If you don't want to send your laptop to Dell then you will have no other choice but to take the laptop to a reputable PC repair shop and have them change the graphics card for a new one, or you can try to do it yourself.
    If you decide to attempt to do it yourself post the full serial number (S/N) to me and I'll help you source a compatible graphics card for the laptop.
    Regards.
  • Lee Hodgson
    Fantasic!!!
    They're basically giving you a new laptop!!!!! Thumbs up Dell.
    Congratulations to you Gary, you can consider the problem resolved. All the Dell engineer will do is swap out your hard drive with your data on it or offer you a new one.
    Take care.
Clave maestra de laptop dell inspiron 700m service tag 7YPP581
What is the problem with this laptop?
Could you please elaborate further and explain in details when the problem started?
Thank you.
May 29, 2011 | Dell Inspiron 700M Notebook
Describe your Dell Inspiron 700M PC Notebook Problem forget my bios password of dell 700m inspiron notebook
Go to the Dell website or get the manual that came with your notebook. You'll find a diagram showing the board in the comp. Find the pin that clears the BIOS password and follow the instructions from Dell.
Jan 22, 2011 | Dell Inspiron 700M Notebook
Inspiron 700m
The problem you posted i not clear enough, what is the problem with dell inspiron 700m?
Take care.
Aug 12, 2010 | Dell Inspiron 700M Notebook
FN key doesn't work after reformting dell inspiron 700m series
There are drivers that may help on the website www.dell.com/support you will need your service tag.
Feb 04, 2010 | Dell Inspiron 700M Notebook
How to reformat the hard disk of my inspiron 700m
Easy enough To format your hard drive, insert the installation DVD(Vista) and go through the options until you get to choose which partition to install Vista on and just click the button at the bottom that says "Format".
Much the same in XP
Oct 03, 2009 | Dell Inspiron 700M Notebook
Resetting 700m
hi thanks for using fixya!
What do you mean of reset? Do you want to format your laptop?
let me know.
Mar 28, 2009 | Dell Inspiron 700M Notebook
I want a driver for motherboard of dell inspiron 700m please
Hi, go to the internet and go to dell.com then go to drivers & downloads
then select your laptop model Inspiron 700m
OR
here is a link to get all your drivers for your model of dell Laptop Inspiron 700m
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_700M&os=WW1&osl=en&catid=&impid=
hope this solved your problems
Nov 11, 2008 | Dell Inspiron 700M Notebook
Dell inspiron 700m microphone not working
make sure the drivers are installed properly
Aug 31, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700M Notebook Logo
1,482 people viewed this question
Alun Cox
