Question about Garden
Cant get the solution to go through the hose and through the pressure wand
  • 72 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
  • 691 Answers
SOURCE: poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Posted on Jul 21, 2009
  • 60 Answers
SOURCE: no pressure when hose and nozzle are attached but when i disconne
sounds like nozzel has dirt in it -try removing and cleaning it - failling this get a drill bit of same size of hole in nozzel and drill hole clean.......
worked for me with same problem..........
P
Posted on Aug 07, 2009
  • 109 Answers
SOURCE: I have a Husky pressure washer with a Honda
check the quick disconnect to the wand these are spring operated and can get stuck
Posted on Aug 23, 2009
  • 7 Answers
SOURCE: No pressure
you will have to try the following start up purge up onece with just water then start the powerwasher if that does'nt give u pressure ther is gaskets inside the pumping sometimes 4 to 8 of them these might be to wore down to hold pressure if u can locate the pump and desemable it run it to ur local dealer tell u need new gaskets put into it
Posted on Apr 09, 2010
Low water pressure from wand
The pressure in a watering wand extension to a garden hose is related to the water pressure from the hose itself.
The point of a watering wand is to provide a gentle and widespread flow of water. If you are looking for a powerful stream, then a different type of attachment is required.
Check to make sure that there is no leaking at the faucet, or at any connecting point. Leaks will lower water pressure at the end point.
Check to be sure the wand itself is free of dirts and clogs. If the wand is dirty or blocked, it will affect the pressure.
If there are several hoses hooked together, the water pressure is more likely to be low at the last point, the wand itself.
When the water pressure drops as a result of another use, like a shower, dishwasher, another hose faucet, then the water pressure will drop in the wand.
Aug 06, 2017 | Water Garden
Pump does not appear to be working
Disconnect wand/hose with water to pump run machine. If high pressure water comes out of wand/hose port, bad wand or hose. If no high pressure water, bad pump.
Apr 27, 2016 | Garden
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Stanley motorised pressure washer. Cant get the water to flow
Disconnect the wand from the washer if you get water coming out of the discharge, the problem is in your wand or the line is plugged going to the wand.
Feb 27, 2015 | Stanley Garden
Where does the detergent bottle go
It goes onto the wand itself. With the Pressure Washer off: If you have the wand unattached from the hose it works easier. Then separate the WAND into two pieces at the big joint in the center. Insert the bottle into the joint on the opposite end of the section that will be attached to the hose, (once you have the wand in two pieces you will see the same types of connections that are on the bottle.) then attach the other end of the wand to the bottle. Now reattach the wand to the hose.
Dec 03, 2014 | Campbell Hausfeld PW1750 Electric Pressure...
Pressure washer was working fine then it shut off. and now I cant pull the string
Whoa! Wait when water pressure is at hose you have to pull the trigger on wand to release pressure so the engine can turn freely. It has so much pressure at wand that it will not let you turn enging over. If not It may have froze up. Check the oil first , no oil then it is locked up. If not you can remove pull rope cage and try to turn it manually.
Oct 01, 2014 | Garden
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
Poor pressure and water comes out of the detergent hose
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
