Question about Boating
Have a 2004 3.0 MerCruiser -have winterized( drained block & exhaust) but don't see where you add anti-freeze as unit will be outside to Spring-live in Michigan.Thanks
  • 86 Answers
You do not need to add antifreeze. If it has 2 blue hoses on the right side of engine then pull those and point down towards the bilge. If it does not have that then pull the plug on the right side of block. Pull the plug out of the bottom of the exhaust manifold. Loosen the hose clamp on the water pump and pull the hose off. Put the hose clamp and the 2 plugs into a ziplock bag and ziptie them to the steering wheel so you dont loose them. That is all that you need to do. You should also use Sta-Bil to stabilize the fuel in the fuel tank. Then you are done!
Posted on Oct 16, 2009
How to replace antifreeze in 2003 ford expedition
once you get the correct anti-freeze for the car, drain the radiator and if your so inclined you can remove the block drain plugs to drain the engine block. close up all drains and then add your anti-freeze. add one jug of water with one jug of anti-freeze to get the proper mixture. when the rad is full run the motor to operation temp and make sure the coolant system is full as well as make sure the overflow bottle is full.
Feb 23, 2015 | Ford Cars & Trucks
Winterize vcross 365 fifth wheel
I think you have posted this several times so I wanted to add this.
The best thing is to have a dealer do it. You need to know if you have by-pass kits installed, depending on what you have for storage tanks they need to be drained, RV non-toxic anti-freeze needs to be added to plumbing and flushed through, water lines should be blown out along with draining so if there is a place where the water was level it gets forced out.
Here is a quick info for a skyline, but it really depends on what you have for plumbing.
Purchase 4-6 gallons of RV approved, non-toxic anti-freeze.
2. Drain all tanks, fresh water and sewage tanks.
3. Turn water heater by-pass valves to by-pass position. (The by pass valves are located near the
water heater incoming lines - an access panel may have to be removed depending upon the
model.)
4. Drain water heater.
5. If installed, remove water filter from assembly and discard. Install diverter if included.
6. Pour an amount of RV non-toxic anti-freeze into the fresh water tank to fill the tank above
minimum water pump operating level. (Use of a long funnel may be helpful) Add more, if
necessary, during procedure.
7. Turn on pump switch and open the cold water side of all faucet fixtures. Leave open until the
anti-freeze comes out (generally, pink in color). Repeat for hot water side.
8. Flush toilet until anti-freeze begins to flow into the bowl and then pour one gallon of anti-freeze
down the toilet to winterize the black tank.
9. Pour anti-freeze down each shower/tub, lavatory sink, and kitchen sink to fill p-traps.
10. To winterize gray tank(s) pour one gallon down each related sink drain.
*****Now the best thing is to post a new post and see if someone has your manual to be exact.
But if you get no response, and refuse to let a dealer do it, you have a little bit of info to help you.
Sorry I couldn't find the exact method for your model.
Apr 09, 2013 | Sport & Outdoor - Others
Water leakage on exhaust manafold
Need more info,Amber. Is it water or anti-freeze? Which side of the engine? Are you seeing a drop in the level of anti-freeze in the expansion tank where you add the anti-freeze? Is this a 4.0 V-6 engine or a V-8 engine?(:^) don-ohio
Oct 30, 2011 | 1996 Ford Explorer
Should i drain the cooling system on my 2001 mercury sable
Every 5 years,you really should,if you put more than 10,000 miles a yeasr on it.
Check the coolant for freeze protection every year and every time you add anti-freeze or water after you've run it for an hour or more(to let it mix thoroughly into the expansion tank).
If the coolant has been in there and has a dirty look, even if it tests good, you should do a flush.
Your heater has a bypass hose above the hoses that connect to the heater core. So just take a pair of clampin end vice grips and clamp off the hose before it enters the heater core(this is if you have a great heater and KNOW the heater core doesn't need flushed).The block on your car has a drain plug(allen head,I believe)on each side of the block down low towards the front.You can remove these to do a great flush or you can just keep flushing water hose water thru the radiator. The sequence is this...........
(1) Drain all you can out of the radiator(there''s a big plastic cover under the car you need to remove to get to it on the driver's side radiator).
(2)You can remove the engine block drain plugs or not,IF you really flush it well.
When you are satisfied you have most anti-freeze replaced with water, you start the car with the proper level of water in the expansion tank,and add your flushing agent.Of course follow its directions, but after running the car for a few minutes, be aware you may need to add more water as the thermostat opens.
(3)After draining out the dirty water,let the engine cool for at least an hour,then fill it with HOT water to prevent any cracking of block or heads.This also you drain out and let the engine cool all the way down.
(4)NOW you're ready to fill with full-strength anti-freeze(Prestone or equal quality)but don't use the 50/50 strength.Becausde your engine has water in it, you will blend automatically.
(2) Two gallons of antifreeze will do nicely to give you a 60 anti-freeze to 40 water ratio or thereabouts,and that will test to greater than 40 below zero F. don-ohio
Oct 11, 2011 | 2001 Ford Taurus
Need to flust anti freeze.Anti freeze is a thick ,gummy texture..
if the anti freeze is not serviced regularly the dexcool will start sludging up the system
if the old type (green)anti freeze was added this will also cause the same.
drain system completely & add water,run for 10 -15 minutes & drain.do this a couple times
& then add a good flshing agent with the water.you may need to do this several times with
flushing material.after it looks better.add anti freeze & consider reflushing 1K miles or so
dont forget to bleed the system of air. bleeder valve(flat head screw) near thermostat
good luck
Jun 22, 2011 | 2004 Pontiac Grand Prix
I don't know if there is a place to drain the air conditioner unit.
jbuck, Since your unit is a multifunction unit (AC, Heat & Dehumidifier) you don't have to darin any water. It uses an evaporative system, that exhaust the water/moisture thru the exhaust hose to the outside. With that said, there may be a rare occasion, that the condensation pan under the unit, needs to be drained. In which case, you will find the drain hole, covered by a plastic screw off cap, on the left rear of the unit (as you face the rear of the unit), next to the cord keeper. A small plastic bowl or pan that will fit under the drain hole will suffice. As, there shouldn't be that much water to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | Haier CPN12XH9 Portable Air Conditioner
Can i mix water and anti freeze in my car
yes just pour in rougly equal amounts of water and coolant or use the ready mixed type avail at any auto parts store, the ratio is 50/50
Aug 25, 2010 | 1997 Plymouth Breeze
Radiator flush for my suzuki forenza.
For the do-it-yourself kind of mechanic, there is a kit sold by Prestone that will help you back flush the system using an ordinary garden hose. Available at most any auto-parts store, Walmart & such. It has the basic instructions on the container but I'll give you an overview.
You will need a large container to catch the anti-freeze coming out, You could drain it by removing the plug at the bottom of the radiator first , or remove the lower hose & get most of it out & then just flush the remainder, back-flushing is recommended.
There is a piece that fits into the radiator caps position that helps to aim the water towards a container but sometimes you can't use it due to size restrictions & limitations on space & have to catch the fluid with a drain pan as it overflows.
You will need to install a backflush connector "T". You simply cut into one of the 2 heater hoses, preferably the return line, and install that piece using 2 hose clamps to secure it. The garden hose hooks there.
The engine should be cool, you can crack a head or block by drowning a hot engine with ice cold water.
Just turn the water on slowly, once the anti-freeze stops coming out & it's just water, remove the drain pan & recycle what anti-freeze you can. Remember, most anti-freeze is fatal to birds & animals, including large dogs & children, so clean spills or at least dilute it with water until it is not a threat.
once done, drain the system & refill with the mix you prefer for your area, usually not less than a 50/50.
good luck.
Feb 18, 2010 | 2004 Suzuki Forenza
I am a builder. I installed my Bosch dishwasher.
Hello Gerry, There are two (2) ways to accomplish this. The easiest is to get some RV anti-freeze (enviromentally safe version) and put that into the bottom of the dishwasher as per the instructions. Then when you return in the Spring, just run an empty rinse cycle to purge the dishwasher of the anti-freeze solution.
The other method will require you to remove (pull out from under the cabinet) the dishwasher and (with power turned off!) disconnect the sump pump boot to drain the residual water out of the unit. In some models, there is a small drain plug that you can remove to drain the water out of the bottom sump (pump) section of the dishwasher.
Good that you thought of this, as many folks forget that leaving water in their appliances in freezing conditions can cause some major headaches from burst pipes, pumps, etc. if they aren't properly winterized for the freezing temperatures they'll get in an unheated building.
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Bosch Dishwashers
What type of anti freeze should I add?
Suzuki forenza uses Green silica based anti-freeze. If you mix the wrong kind with it, it will gum up your thermostat (90 dollars) and potentially mess with some of the smaller cooling fluid tubes and passages. Not to mention, the water pump is not to fond of gritty fluid. So if you see discoloration in the bright green fluid, better drain it, flush the system out with a garden hose for 5 to 10 minutes, and refill it with new fluid.
Oct 27, 2009 | 2004 Suzuki Forenza
Boating Logo
411 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
