Question about HP 920 Plain Paper Fax
How do i connect a fax machine which wires go where
    Problem Solver:
  • 9 Answers
You can download the reference manual from HP but the wire from the wall jack goes to the back of the 920 is is written as such. The answering machine or phone goes to the jack adjacent to it.
Posted on Nov 24, 2009
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
Why is there no dial tone?
Connect a telephone in place of your fax machine. Listen for a dial tone. If you hear it, something is wrong with your fax machine connection.
Aug 15, 2015 | Brother IntelliFax-4100e Fax
Where do you connect the wire to the fax machine
Dear
The telecom company line to be connected where it is marked as LINE on the machine. In general there are two sockets (RJ11) at back or side cover of the fax machine.
Thanks.
Jan 31, 2015 | Office Equipment & Supplies
How do i connect my hp 1240 fax\printer to my computer
The fax must be connected directly to the wall phone jack. Connect any other phone line devices, such as a telephone or answering machine, to the phone jack on the back of the fax
The phone line cable used to connect the fax must be a two-conductor (wire) phone cable, like the one that shipped with the fax. The fax may fail to send or receive faxes if the phone cable has more than two conductors. To determine how many conductors the phone cable has, look at the end of the cable. Most phone cable connectors are clear and you can see the number of wires
The Rings to Answer setting determines how many times the line will ring before the fax answers. Follow the steps below to change the rings to answer setting.
  1. Press Setup , press 3 , and then press 3 again to access the Rings to Answer setting.
  2. Press the Right Arrow to scroll through the available settings. When the desired number of rings is shown in the display, press OK .
To receive faxes manually, follow the steps below.
  1. Answer the phone like you normally would a telephone call. If the incoming call is from a fax machine, you will hear beeps or fax tones.
  2. Press either Start Black or Start Color to begin receiving the fax.
  3. Hang up the phone.
Jan 15, 2011 | HP 1240 Plain Paper Inkjet Fax
The fax machine will not send a fax. What should I check to fix this problem.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
Brother fax machine no outgoing fax
If you can't send faxes there is not a good connection to the wall.make sure the phone wire is going into the line jack(not ext) and that it's going directly to the wall (no splitters or extensions)
if that doesn't work try it with another wire or jack
Mar 19, 2010 | Brother Personal FAX-275 Roll paper...
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
HP 640 Fax...can't recieve faxes
You cannot use a four wire cable to connect the fax to the wall. You must use a two wire cable, like the one that came with the machine.  BTW, that means you can't you the EXT port to connect a two line phone or answering machine.
Sep 04, 2008 | HP 640 Inkjet Fax Machine
Hp5500 series fax machine
Plug a regular phone into the wall jack and call a fax nunber, listen for fax tones. You don't have DSL, do you?
May 12, 2008 | HP 640 Inkjet Fax Machine
Fax machine phone connections
I beleive it's because they are grounding out on the fax, which then resets some of the functions.
Did you measure if there are any activity on those two lines?
V or Hz?
Jan 30, 2008 | Brother IntelliFax-2820 Laser Fax
HP 920 Plain Paper Fax Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
