Question about Dryers
Dryer does not start, took laundry out, next thing the dryer will not start.
  • 61 Answers
Make sure circuit not triped
Posted on Sep 28, 2009
Kenmore dryer timer 11086873800
Could be the door switch. Make sure it's closed all the way you should be able to here a click if it is working.
May 05, 2014 | Dryers
I went 2 rotate the laundry and the dryer would not turn on for the next load, the start button made a clicking sound, but would not start....
Check to see if the belt is broken or if the dryer has blown a fuse in the panel (2 30 amp fuses)
Nov 30, 2010 | Kenmore Dryers
I have a kenmore 11074632300 when starts off from a cold start the first few times it fires up with the gas and there is no issue. After the dryer heats up a few times it will fail to start again until the...
next time you take the lint filter out to clean it, take it to the sink and pour some water onto it. Some filters, even from new, can have an oily substance on them that can block the mesh. If the water does sit on the mesh, you need to wash it with warm, soapy water to clean it. This allows the air to travel through it more freely and dry more efficiently. If the hot air builds up inside the unit, there is probably some sort of thermal overload detector that will shut the gas off
Oct 06, 2010 | Kenmore 74632 Gas Dryer
I dried a load of laundry in my dryer. Took it out and added another load. The dyer would not start. The door switch appears fine. What else can I check?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Dryers
I have a stackable washer and dryer the washer works but the dryer when I turn it on it starts and the drum starts to role then it cuts off and I can smell a burning smell I am so tired of washing clothes...
a number of things but first unhook the electricity and take the back off the dryer look for burnt wires ect... it can be plugged with trash lent ect clean out the dryer including the blower wheel housing follow the vent to the housing that is it. Also the next biggest culprit is the elect motor its self if its bad you can order one from the company that made it or a number of companys on line(they will be cheaper) good luck and replace your belt while you are in there.
Aug 08, 2010 | Frigidaire Dryers
The dryer part started to make a noise as if a sneaker was inside tumbling around.. next thing I know the two screws that attached the drum fell off and it completely stopped working
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
5665thg
Jan 27, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer wont start
Hello. i can help you. begin by checking the power.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
If that doesnt get it working again get back as there are other things that could have gone wrong.
Jun 04, 2009 | Dryers
My dryer wasn't drying like normal. It took more cycles to dry my laundry. I checked the exhaust and found the exhaust connection "hose" wasn't adequately connected and had a few small holes in...
Hello Chritena,
Based on your description.. I'll throw some ideas at you for you to try.. Not sure if you have an electric or gas dryer but that shouldn't make a difference .. Try unhooking the exhaust for a few minutes and start the dryer.. If it is a gas dryer.. do this with plenty of ventolation since the byproduct of gas combustion is unhealthy.. If it is electric.,.it isn't healthy but it isn't bad either.. let the dryer run until you feel good hot air flowing out.. If the flow is weak then chances are you have either a blower problem or restriction in the blower system inside the dryer,, If you get good hot air flow, then you probably have a restriction in your ductwork or the outside vent cap itself.. These are the main areas to check.. let me know the outcome of these checks and if they fail to resolve the problem.. will dig a little deeper.. Next time, please provide the model number too.. it helps focus in on the specific details...
Regards
Oct 11, 2008 | Amana Dryers
Dryer just quit
I would check to see if you have 220v to back of dryer where the cord mounts to dryer Check the door switch, , Take back off dryer There is a fuse in the back its white oblong 2 wires coming from it, left side on blower outlet ..be carefull hook the 2 wires togather and if it comes on the fuse is bad needs replacing same way with the door switch.
Aug 29, 2007 | Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
