Question about Ovens
Gas oven not firing to correct temperature
I have a gas oven which ignites straight away but is not firing up to correct temperature. Can it be corrected, if so is this expensive or shall we just buy another?
  • 42 Answers
If the flame in the oven is staying on low you will need to replace the fsd.
Posted on Sep 28, 2009
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
Oven starts and stops
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 02, 2014 | Kenmore Ovens
No gas to oven
Mar 01, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
Mod# xfg374lvq stove: Both the oven and the broiler will ignite, but only stay on for a few seconds. It does not try to reignite. Is this the control module?
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven sensor: works with the oven control board to regulate the oven temperature. If there is an oven temperature problem, this sensor might be defective. The sensor can be tested by using an ohm meter. As temperature rises, the resistance measurement also rises. The manufacturer of the oven sensor determines the correct resistance, Oven temperature problems can be caused by other things, but this is one of the common causes.
Beware on some models now most of these ovens they are electronic and they are integrated into the control itself
some different sensor ohm readings at room temp. approx 16 ohms at room temperature and at 350?F it is 29~33 ohms.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Oven Won Turn on
Oct 09, 2013 | Whirlpool Ovens
Model # 36275621302 stove not maintaining proper temperature. Takes long to bake. Broiler comes on ok. Bottom burner gas comes on and ignites in preheat but then the igniter glows hot but the gas doesn't...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 28, 2010 | Kenmore Ovens
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
Ovens Logo
95 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
