Question about Polaris Pb4 - 60 Booster Pump
Need instructions on how to replace seals - Polaris Pb4 - 60 Booster Pump
  • 366 Answers
Ok, I will try my best. First, make sure power is off to the pump. Then, remove the six bolts and nuts on the front (wet) end of the pump and expose the impeller. On the back of the motor, you will need to remove the small dust cap in the center. Underneath that dust cap should be the shaft that is slotted. You will need a large screwdriver to hold it from turning as you remove the impeller by turning it counter-clockwise. Once the impeller is off, remove the four bolts holding the seal-plate onto the motor. Once you have the seal plate off, press the old seal out by pushing from behind with a flat tip screwdriver. Once the (ceramic part) seal is out, clean the area where the seal seats very thoroughly and apply some silicone lubricant or even Vaseline to for a nice uniform coat to the area, don't leave any of it dry but don't glob it on either. Next, pull the carbon/spring part of the seal off of the impeller by twisting pulling it at the same time. Make sure all of the seal comes off including the rubber washer/o-ring. Apply a very small amount of lube to the impeller shaft where the new seal will go. Install the new seal onto the impeller, be careful not to touch the carbon face of the seal if you can help it. Slide the seal all the way onto the shaft until it bottoms out. Next, install the ceramic part of the seal into the seal plate, be careful not to touch the ceramic surface. Press it into place using some paper of cardboard from the box the new seal came in. Make sure it seats all the way down, inspect it from the back to make sure the seal is completely seated. Install the seal plate back on and torque the four bolts onto the motor. Thread the impeller onto the shaft until it bottoms out, hold the shaft and tighten the impeller lightly, no need to crank on it, snug is good. Check and lube all your o-rings and install the wet end back onto the seal plate. Reinstall the motor shaft dust cover and you should be back in business. Be sure to fill the pump with water before turning it on. You can usually do this by starting your filter pump first.
Here is an exploded view of your booster pump.
http://www.poolpartsonline.com/popup.aspx?src=wolthuis.aspx%3fproductid%3d12%26size%3dlarge
Posted on Sep 28, 2009
    Problem Solver:
  • 10 Answers
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
Howh do i replace the gasket pad
Nancy,Could not find instruction for seal removal on your particular model, did post links to models, hoping they will be close/same as yours. Check the attached links,instruction and guides, Good luck
Dryer Door Seal part WP3405245 How To Replace
How To Replace Torn Or Worn Out Dryer Door Seal
Dryer Door Seal part 33002094 How To Replace
Jul 10, 2016 | Maytag MDE2400AYW 24 High-Efficiency...
1992 f150 front axle to diff. seal replacement
OK, you must remove the front axle assembly to access the axle flange and then the seal, follow the instructions at the link but once the axle is out remove the axle flange from the front diff and replace the axle seal, use a seal driver and lube the new seal with lithium grease (white grease). You will need an air impact to get the flange nut off, replace it with a new one (do not reuse) and do not over tighten it. Cinch it down and then go about 1/8 more of full nut rotation to preload carrier bearing setting then spike in place. Ford F150 Front Axle Replacement Part 1
May 19, 2016 | Ford F-150 Cars & Trucks
Repair leak in ac compressor
Ed, Check the attached links,instruction and guides on A/C seal replacement. Good luck
How To Rebuild your compressor Just in time for summer too
1993 Toyota Pickup ac compressor seal replacement Google Search
Denso 10S Series Compressor Reseal
Denso 10P Series Shaft Seal Replacement
Apr 08, 2016 | 1993 Toyota Pickup
Cannot remove rubber door/drum seal on whirlpool 1000 awz 410
I also need to replace the door seal on my Whirlpool AWZ 410 washer. Does anybody have detailed instructions of how to do this for this particular machine model (not generic instructions) & know if it is necessary to remove the front panel on this machine in order to remove the existing seal please?
Feb 23, 2013 | Washing Machines
Black marks appearing on towels. Look like marker, smudged.
hi.
it could be the seal on the front of the drum starting to break down.
clean the seal at the front of the drum that seals the door. then rub a white cloth/towel around the seal
if there are any marks left by the seal then the rubber compouds are starting to break down and the seal needs to be replaced.
please feel free to ask for detailed instructions on changing this seal if you need them
Apr 13, 2011 | Frigidaire GLTF1670A Front Load Washer
Leaking oil badly in front of engine??? need help!!
Its either depending on the size of the engine, the valve cover gaskets or the camshaft seals, or crankshaft (front) seal leaking . Can tell by getting engine dye , whitch you can purchase at any autoparts store and put in engine oil fill and run car for 30 minutes or so and put a black light on engine area where leaking , start at the highest point first.
Feb 11, 2011 | 1997 Plymouth Breeze
Dana 60 axle seals replacement
changing pinion seal on 79ford e-250 dana60.are there any cautions or recommendations concerning torque or preload.
Dec 19, 2009 | 2006 Ford F-250 Super Duty
PS-1000 Seal
The seal replacement on most pumps requires the capacity to separate the motor from the pump and to dismantle the wet end. Upon dismantling, it will become clear as to where the seal components are to be replaced. The spring half is found in the seal plate and must be knocked out and reinstalled with a properly sized driver and the ceramic seat is attached to impeller. Be careful not to damage the polished surfaces of seal. A light coating of a silicone or teflon based lubricant is most helpful ..
Apr 12, 2009 | Waterway Pump Part Seal Set Ps1000 Cd 319...
I need instruction & schematic to replace rear axle bearings & seals on a 1986 4runner sr5
Good news mate!You don't have to touch the bearings at all !!! Just replace the seals, highly unlikely the bearings are toast, had the very same problem and advice from local repairer but another (honest) mechanic suggested to change the seals only and it worked.Remove old seals using a large flat bladed screwdriver taking EXTREME CARE not to scratch the housing, tricky bit is to replace the seals as they have to go in SQUARE to the housing, use a large socket if available or a flat piece of steel to rest against the seal and hammer in SLOWLY AND CAREFUL, ALWAYS SQUARE ! to the housing, take your time and do it a bit at a time, the further in you go the easier it gets, make a note of the final position of the old seal before removal, do a sketch or take a photograph, also take care when reinserting the prop shaft back in the axle housing not to damage the new seal. Good luck !!!
Oct 19, 2008 | 1986 Toyota 4Runner
Polaris Pb4 - 60 Booster Pump Logo
814 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
