Question about Casio Music
Fredy 2 I am trying to play chords with my fingers, there is no sound, if it is on any other mode the chords work but i need it to be on fingered mode thanks doreen
  • Casio Master
  • 5,603 Answers
OK... It wasn't clear from the original.
Sometimes the keyboard has a mode that splits for upper and lower part of the keyboard, usually splitting at the F#/G. Also CERTAIN voices will ONLY sound one note at a time. Piano setting would not have this problem of course.
When you play a single note does that sound? If it doesn't in the fingered mode, then there may be a processor problem in the unit/
If it does, there is probably a problem in the matrix that scans the keyboard electrically. If one of the keys were ELECTRICALLY stuck on, the processor within could not read whole sections of the keyboard.
To troubleshoot the problem, press exactly one key at a time... do they all work for say a piano voice while in the fingered mode.
Next press a key at the high end of the keyboard and try others. See if you can find an octave that fails to work.
The problem is likely imbedded in the electronics and could be anything from a dirty key contact to a cracked circuit board. It is NOT likely you can fix this yourself unless you are experienced in electronics.
Posted on Sep 28, 2009
Testimonial: "hi fred2 there are some chords which will play and some wont, I will take it in to an electronic engineer to check thanks anyway for help.Doreen "
What are all the left side controls on an Elegance JC-618 electronic keyboard
Single and Finger,is chords mode.
In Single,by press one key (eg:A) then chords A is heard,and so on.
In Finger,you must press 3 keys.Example: G-B-D,then you heard G chord. D-F#-A is D chord.
In Finger,lets say you press A chord and want to change to C chord by press one key C only,there's nothing change untill you press C-E-G.
Low, is for chords octave low.
Chords Off,no chords can be play,it mean overall full piano mode..
Single,Finger,Low, can be activate with Sync Start button.
Aug 17, 2015 | Music
Ultimate guitar guitar tabs
Here are the chords:
http://chordsworld.com/the-madden-brothers-we-are-done-chords/
Don't be confused by the video. The guy is capo'd up a whole key, so his fingered G actually is the A shown on the chorded lyric sheet.
Enjoy.
Jul 24, 2014 | Homespun The C-A-G-E-D Guitar System Made...
Can I hit one key to play a chord and how do I do it
It depends exactly on the model of keyboard you have but in short look for the accompaniment button normally on the left hand side. With this pressed you can then get 1 finger chords in the left hand ( 2 fingers will give minor or 7th options ) check your handbook
Jul 12, 2014 | Yamaha Full-Size Keyboard
Yamaha psr 1000
Hi
I'm not sure I completely understand your problem but......it sounds like you might be in "Fingered On Bass" mode. This means if you play a chord like F using the notes FAC- if you play them in 2nd inversion (so the order is CFA) the psr-1000 will make the note "C" the bass note. In this mode if you played ACF then "A" would be in the bass part. Change to "Fingered Chord"-this will enable you to play any chord with the tonic (the name of the chord) F whether you play FAC, ACF or CFA in the bass part. I don't have access to a psr-1000 but often with Yamaha instruments this can be changed by pressing and holding the "Auto Accompaniment" button. I hope this helps.
Musicwez
Aug 04, 2013 | Music
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
Wisdom required
If you can find the C-below-middle-C ?
Put your small finger on C,
your next finger on the next white key: D,
your middle finger on the next white key: E
your index finger on the next white key: F
your thumb on the next white key: G
Lift your fingers away from D and F -- to keep this simple -- all we did was identify the D and E and F and G keys, relative to the C key.
Press C and E and G (small, middle, thumb)
to play a "major" chord in C.
Move your fingers "up":
C to D, E to F-sharp, G to A,
and play a "major" chord in D.
D to D-sharp, F-sharp to G, and A to A-sharp,
and play the chord in D-sharp (usually called 'E-flat').
D-sharp to F, G to A, and A-sharp to C,
and play the chord in F.
Move your fingers "up",
F to G, A to B, and C to D,
and play the chord in G.
Go back to the starting position (C-E-G),
and move "down": C to B-flat, E to D, and G to F,
and play the chord in B-flat.
So far, you have C-major, D-major, E-flat-major, F-major, G-major, and B-flat-major.
There are more chords, but most pop-music is in one of these keys.
Give it a try.
A lot of left-hand stuff is just the small-finger and thumb, omitting the middle finger, e.g., C&G,
to avoid a too "muddy" sound.
Or, "stretch" your hand: C-and-G-and-the-next-higher-C.
Jan 14, 2010 | Yamaha Full-Size Keyboard
Casio tonebank ct700 no sound from chords only whilest on fingered chord please advise
More info. If you are chording on the left half of the keyboard, SOMETIMES they allocate or have the option to select a different voice for the part where chords are played. For these, you have to ALSO select a voice for that half of the keyboard. If you don't select a voice, then you would not have anything sounding.
Sep 27, 2009 | Casio Music
No chord will play while in fingered mode it is a casio tonebank ct700 model
NORMALLY "fingered" mode means that you have to "finger" the chord, that is, play all the notes of the chord. It sounds like it IS working as designed.
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
135 people viewed this question
Top Casio Music Experts
Ben Armstrong
Matthew Spark
Matthew Spark
Are you a Casio Music Expert? Answer questions, earn points and help others
