Question about Sanyo DS25390 TV
I have a good picture then it goes horz. with static and then a good picture and then a horz. lines and static about every sec.
  • 108 Answers
The horizontal line indicates failure of vertical section, checkout the output capacitor of vertical-section connecting to the yoke (vertical) for any loose contact, dry solder, capacitor wear-out.
Need to check the register and filter capacitor that powers the vertical-section.
Posted on Oct 14, 2009
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
Very wide pink and green horz lines, no picture
CLEAN Y SCAN RIBBON CABLES WITH CONTACT CLEANER AND COMPRESSED AIR IF THEY DONT DISAPERR REPLAC Y SCAN BOARDS
Apr 25, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Hi, Two sets of lines have appeared on the screen
are these lines vetical or horz if they are vertical your panel has failed and will need to be replaced big bucks if they are horz , then it could just be the T-con board and you will need a tech to confirm this I have seen this problem cause by a poorly seated connection
Dec 07, 2009 | Televison & Video
My monitor goes black with a horz white line across the center. It is a Lacie on a g4 mac . It is about 6 years. old.
The lcd is bad usually the lines start very small and rapidly over time become about an inch or so thick.
Oct 07, 2009 | Computers & Internet
Kp-fs57 blue screen then turns off
Could be one of three things the yokes, the flyback transformer or the picture tubes, all will be a costly repair. If it was mine I would invest the money in a new one.
Sep 09, 2009 | Sony KP-51HW40 51" Rear Projection...
I try to vibration pcb but samething problem on many horz line on picture.
Please intimate exact model and brand of your TV that you are looking for info.
Thanks.
Jul 19, 2009 | Samsung DLP HL-P5663W 56" TV
My rear projection tv has squiggly horizontal lines in the picture. Sometimes when I turn it off and then turn it back on it goes back to normal but it is steadily getting worse. Any suggestions would be...
I have seen this on quite a few Mits's as they are getting to that age. This is usually related to bad caps in the signal path. I could go into more detail if I knew the exact Model Number (it will start with WS or VS) Example VS-60609. But the caps are usually near the 5v regulators.
Jul 09, 2009 | Hitachi Televison & Video
RCA TV 32V434T transformer?
When the HVT goes out, it will take the HORZ output, in short, you will hear a high pitch noise for a sec, when pluged in. As to your question, Its not a hard repair, however its not what I would call a begainer repair. This is what make the high voltage (about 32,000 volts) for you set to work. If you DO try it, becareful. And don't forget to change Horz output p# 274762. After changing the parts, unit will not run for more then 10 seconds. You have to use a volt meter and set the G2 for 290v, with no signal and blue screen. + or - 5 volts will cause unit to shut off.
Tvman
Jul 14, 2008 | RCA 32V420T 32" TV
Sony TV not working
This is not an easy fix for most people! I suspect the ps is blown, R607, Q601,Q602 (use all org Sony parts, lots of factory 2nds around). This stuff blows to protect the fuse!!!!! Very rarely the input bridge rectifier or filter cap short.
Check R622, if open or discolored also replace VDR601(doesn't go bad very often). Check Horz output Q502. Inspect whole board for any bad connections, all parts with heat sinks(regulator ICs). Horz driver transformer, 0.47uf to horz driver tr. There could be other parts bad (flyback??). Make sure no supplies are shorted, check audio output supply, vert output supply, etc. Easily $150 repair at a shop. Good luck!
Oct 27, 2007 | Sony KV-32S36 32" TV
Televison & Video Logo
119 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
