Question about Zenith P50W38H 50 in. Plasma Television
P50W38H screen flickers and red and green pixels shimmer
After about 10 minutes the red and green pixels start to shimmer and the screen blinks every 15 seconds. The blinking increases to every second or so after a few more minutes. If I interrupt the video by opening the DVD tray the screen is fine for about another 10 minutes. It also had purple vertical bars which started weeks before the pixel and blinking problem.
  • medussa_89 Jan 04, 2008
    green and red pixels show up ever now and then, making it diffcult to read the screen
    Top Expert:
  • Zenith Master
  • 75,017 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Dec 03, 2017
  • 3130 Answers
SOURCE: nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Posted on Oct 08, 2006
  • 136 Answers
SOURCE: Sony Bravia LCD Flickers/distorts
More than likely this is a bad display (lcd screen) the drivers in the lcd display are going out and unless its under warranty its very expensive to repair. Sorry :-(
Posted on Sep 15, 2007
  • 137 Answers
SOURCE: Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Posted on Dec 22, 2007
SOURCE: lamp indicator blinks red
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
Posted on Jan 02, 2008
  • 60 Answers
SOURCE: Zenith E44W46LCD 44 in. Rear won't start
The buzzing is the ballast for the lamp trying to light the bulb. From what you've described it is a lamp failure. It's not that hard to change but you'll have to obtain a new lamp first. You can try and buy it from LG (800-243-0000) but I'm not sure if they'll sell to a consumer. Then you have to reset the lamp timer after you replace it. Hold the mute on the remote and the enter button on the tv at the same time for about 8 seconds and a screen will come up asking if you want to reset the timer. Just follow what it says to reset it.
Posted on Jan 03, 2008
The screen turns green after playing videos for 20 minures
The Video Controller works off of the RGB principal. RED/Green/Blue pixels. The mix color is dependent on the formation and density of the pixel and rates. When one or more colors are absent the only functioning color will dominate, and it is Green in your case. The screen liquid crystals in Red and Blue are failing and only a screen replacement will fix the situation.
Jan 04, 2015 | Toshiba C655D-S5200 Amd Dual-Core C-50 3Gb...
My Sharp 32 inc turn off suddenly, power green light turn to red, went turn on again screen ok for 5 to 10 second and start blink 3 time and screen turn off and power light change back to red. What...
sounds like something is shorting and the safety on the psu is kicking the backlight behind your screen flickering prior to it cutting out. if so sunds like a cft has gone faulty. can be fixed though
Jun 08, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
My dell monitor has three large green shimering boxes across the bottom of the screen that I can't get to go away. Powered on and off, unplugged, plugged....
Shimmering boxes and/or LCD screen has spots = this is due to Missing /broken Pixels.
- These are pixels that are permanently off and is a natural defect that occurs in LCD technology.
Solution (1) = Do a reset on All Settings.
Solution (2) = If Solution(1) does not work, you may need to replace your monitor.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
RGB Pixels
sounds like the graffix card maybe over heating you will probably get e74 error and have to send it in same thing just happened to me.
Jun 08, 2009 | Microsoft Xbox 360 Console
Pink highlights on LCD screen
Jun 02, 2008 | Televison & Video
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Picture - Flickers/Shimmers
I think the solution to your problem is adjustment, not of the brightness but either the `contrast' which is probably too high, or the `sharpening' if your set has this function. Too much sharpness will cause a shimmering effect, especially where you see an edge between colours.(due to ringing at a very high video frequency). Too much contrast can start to turn the video signal upside down, causing noise on the peak white in the picture. Another cause is if the RF signal into the aerial socket is too large, This can be corrected by an attenuator, costing about £2. 6dB or 10dB can be tried.
Oct 23, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Zenith P50W38H 50 in. Plasma Television Logo
273 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
