Question about Lexmark X5650 All-in-One InkJet Printer
I have the x5650 print and it keeps saying there is a paper jam but I have looked but cant find is there a way you can open it up more? I get the top open but I dont see any paper jamed in it
SOURCE: Lexmark X73 paper jam
please solve my problem
Posted on Sep 26, 2008
ghassun
  • 499 Answers
SOURCE: i have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
Posted on Jun 07, 2009
SOURCE: I have a lexmark x5650 and evertime I try to print
This fixed the problem thanks alot! :) it was the driver update that did the trick. :D:D
Posted on Aug 27, 2009
  • 15 Answers
SOURCE: Lexmark Optra S 1625 202-paper jam open rear door
well with my experience with my opinion crappy lexmark printers there is a senser on the fuser behind the cover it could be jammed down saying there is paper in the fuser when there isnt try lifting it and then flicking it down a few times to work it loose so it springs back all the time and then re-assemble the printer and try it now. hope that works for you had the same problem at work with another model and that is what was wrong with it. good luck
Posted on Sep 02, 2009
  • 15 Answers
SOURCE: My Lexmark X5650 all in one printer displays a paper jam error
Inspect entire paper path for even a little shred of paper. All it takes to block a sensor, or hold down a "finger". if nothing at all, could be one of the sensors are faulty or unplugged.
Posted on Sep 22, 2009
I keep getting paper jam
There may be a paper jammed that you cannot see from the front. Open the back hatch as well and look for paper.
Dec 15, 2013 | HP Deskjet 2050 All-in-One Printer
Lexmark 5660 paperjam
printer says paper jam no paper in printer i have on pluged it to clear it and its continueing to say paper jam what should i do?
Oct 20, 2012 | Lexmark X5650 All-in-One InkJet Printer
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
Printer saying paper jam when there is nothing? I need to fax some stuffs out, please help me. Aloha, Kapua Gordon
Please remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges. Close the cover. Load some paper but don't overload. Try to print again.
Jun 23, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 printer
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Lexmark X5650 All-in-One InkJet Printer
How to Fix a Carriage Jam on a lexmark x5650
Apr 25, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a lexmark x5650 and evertime I try to print something the paper will feed through on one side and not the other so it doesnt print properly. also it says paper jam. any ways to fix this??
if you have a paper jam error and you don't see a Jam it means the printer just needs to be reset.
Please try this to do a partial reset. Leave the printer on and then unplug it and leave it unplugged for about 1 minute and then plug it back in and turn it back on and see if the problem persists.
About the paper feed, first check the printer preferences, go to start, select printer and faxes. Mark the Lexmark printer, click right mousebutton and select properties from the menu list.
Check that you have set paper size to DIN/A4 and adjust your other settings as needed.
If the problem persist check if you have the latest drivers installed, if this doesn't help I think you will need to contact lexmark support.
Aug 26, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a paper jam in my lexmark x5650
Jun 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 All-in-One InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
