Question about Pinnacle Dazzle DVD Recorder
Small screen goes blank when I click on "Start Recording" and I get "record error" I am trying to record to hard drive folder
  • 217 Answers
Disconnect your dazzle then connect it again at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Wait for the new hardware found message comes out and then open your IDVDR again and then do the advance mode. On step number1 choose capture source click the pull down arrow and then choose dvc 100. Turn the power on on your camcorder and run it. Make sure that the video image showed on your preview screen. Try record it again.
Posted on Dec 09, 2009
  • Joey Tagum
    Joey Tagum Dec 09, 2009
How to use webcam on acer aoi-301 labtop
Check this first: Certain Acer laptops come with a built-in Webcam called the "Acer Crystal Eye." This Webcam is located in the center of your lid just above your LCD screen. Those models that possess this integrated Webcam also have a program with the same name. This "Acer Crystal Eye Webcam" program allows you to record video through your Webcam and save it on your hard drive.
Step 1 Click "Start," "All Programs," "Acer Crystal Eye Webcam" and click the program shortcut of the same name. This opens up the Webcam where you can see yourself, but it hasn't started recording yet.
Step 2 Click the video camera icon, which is the one second from the left under the video display. This starts recording the video.
Step 3 Click the video camera icon again to stop recording and save your video. You can also delete the video by clicking the clip's thumbnail on the bottom panel and clicking the trashcan icon.
Step 4 Locate the video file on your hard drive in your "My Videos" folder, which can be found inside your "My Documents" folder.
Dec 14, 2015 | Acer Computers & Internet
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Burn error Instant Dvd Recorder windows 7 Dazzle dvc 100
Set the compatibility back to windows 7 and then uninstall the program and all of it's drivers, then reinstall it and see if it works then.
Jun 08, 2012 | Pinnacle Dazzle DVD Recorder
I am getting the data error (cyclic redundancy check)
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Jan 31, 2011 | Western Digital My Passport Essential...
    Computer does not recognize it as a CD RW drive
    When you try to write data to an optical disc, you may experience any of the following symptoms:
    * You receive various disc write error messages.
    * You experience issues with the drive and the built-in recording feature of Windows XP.
    * You experience issues with third-party programs that you use to write data to the disc.
    * You cannot read the disc in all versions of Windows.
    * You cannot read the disc, or some files on the disk, by using an MP3 player.
    * When you add files or folders to a disc that already contains data, some files are lost.
    * Recording files to the disc is inconsistent.
    * The disc recording operation is consistently unsuccessful.
    TROUBLESHOOTING
    Troubleshooting specific errors
    If you experience one of the following errors, follow the appropriate steps to resolve the error.
    * There is no disc in the drive. Please insert a writable CD into drive.
    This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
    * Drive not accessible, incorrect function
    This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
    when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
    * Error Deleting File or Folder.
    Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
    This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
    To set the service to Automatic, follow these steps:
    1. Click Start, click Run, type services.msc /s, and then click OK.
    2. Double-click IMAPI CD-Burning COM Service.
    3. Under Service Status, click Start.
    4. Try to write data to a CD.
    Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
    I click on start recording, but it isn't recording
    Make sure that the video image will showing to the preview screen of the computer and make sure that the a/v cable is properly connected. Did you already install the driver for your device? Open your IDVDR then choose advance mode, click on next. On step number 1 choose or click on pull down arrow and look for dazzle dvc 100 device. Next on step number make sure that you choose where to save the video. Hard disk folder or DVD disc. If DVD disc choose your DVD writer. Jump to step number and then choose the right time for recording. That's it you may now check and try to start recording your video.
    Oct 26, 2009 | Pinnacle Dazzle DVD Recorder
    How do i record videos with my acer aspire 5735Z webcam. It only takes pictures, and I can't seem to find out how to make it do a recording. audio recording works fine on an indepent program.
    The Acer Arcade software will envoke many options that you can record with your acer crystal eye webcam. The software is preloaded and its just off the start menu under acer software.
    I hope this helps
    or you can use windows movie maker and activate your webcam in there if you so choose. Thanks for using fixya.com
    Jul 29, 2009 | Acer Aspire One PC Notebook
    Errors burning to 1x to 16x DVD-R
    I have had much luck recording on off brand 16X discs as follows:
    1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
    2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
    3) After a minute or so, window will come up and say "Cannot
    complete copy."
    4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
    5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
    6)Let me know if it works for ya. JGIDUSKO@CFL.RR.COM
    Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
    How do you burn a cd on the travelmate 290 ?
    Windows XP CD Copy Windows XP has CD-Recordable (CD-R) disc burning support for most CD writers.
    8b118c9.gif First set your CD-recording options:
    • Open "My Computer"
    • Right-click your CD-R drive and select "Properties". See figure BK-1.
    • Select the "Recording" tab (if this tab isn't available, your device doesn't support CD burning).
    • Check the box to "Enable CD recording on this drive".
    • Select the drive to hold the temporary files (before the system burns a CD-R disc, the system writes the files to be recorded to an intermediary area - this area must have enough free space to hold an entire CD's content).
    • Select the CD recording speed (Fastest, 4X, 2X, and 1X).
    • Select whether to eject the media after recording.
    • Click OK.
    Perform the following steps to record to a CD-R:
    • Insert a blank CD-R disc into your CD burner.
    • Copy or drag the files or folders to be recorded to the CD-R drive, or right-click on the files or folders and select Send To, Writable CD.
    • After you have copied all the files, select the CD-R drive from "My Computer" and you'll see the waiting files as "Files to add to the CD."
    • Right-click the CD-R drive, and select Write to CD.
    • Enter a name for the CD-R disc, and click Next.
    • The files will be written to the CD-R disc.
    • After the system writes all the files, it will eject the CD-R disc (if you chose that option above).
    • Click Finish.
    Jun 06, 2008 | Acer Computers & Internet
    Pinnacle Dazzle DVD Recorder Logo
    206 people viewed this question
    Top Pinnacle Computers & Internet Experts
    AL Schehr
    AL Schehr
    Level 1 Expert
    Alun Cox
     Ian Kayhan
    Ian Kayhan
    Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
