Question about RCA P61960 61" Rear Projection Television
Projector out of alignment
The projector on my tv is out of alignment. the screen is bowing way off to each side and is bowed in on top and bottom. how can i fix the problem
  • RCA Master
  • 8,457 Answers
Ur convergence is dead,buy convergence kit use what inside that kit,U know how to solder right?Tries website Tv Repair World.com.
Posted on Sep 28, 2009
Bowed screen at top
Is It the screen (the plastic/glass) or the picture that is bowed? If it is the front screen, you just need to re-install the screen in the frame. If it is the picture you need to get the projector re-aligned.
Nov 30, 2011 | Philips 60PP9202 60" Rear Projection...
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
53" rca model p52754at
CRT pictures that "bow-in" on the edges usually indicates that the high voltage power supply is failing.
Dec 03, 2010 | Televison & Video
Bowed screen left side top to bottom probably 1 1/2" deflection... need to know how to adjust the projector lenses
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 15, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Wont autofocus, bow in blue color at top, cant adjust blue convergence
hello it's the convergance chips my be the problem get a quote from an engineer its a big job 2 do yourself trust me i've repaired a few my self i hope you get it fixed good luck
shaun
May 21, 2009 | Samsung Televison & Video
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Pioneer elite Projection TV PRO-98
Need to replace the convergence board. Cost through Pioneer is $350.
Nov 25, 2007 | Televison & Video
Pioneer SD-533HD5 - Red bowing at the bottom of the screen
Convergence amp. IC's on power supply PCB need replacement.
Part # STK392-110 sub to upgrade STK394-160E. I use Hitachi ,
no re-calls! Not advisable to use generics......
Worth repairing unless you are ready for a change......T.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red bow at top left and botton left of screen
Lost of high voltage on the vertical amp was caused the bowing. That was a simple tweak. I'm sorry to tell you that the high voltage adjustments are rather precise and have major interaction with each other. The HV circuit is also used to power low voltage circuits to gain efficiency. If one or more are not within spec, the process to recovery will require bench alignment of the various stages. Seek professional help or consider replacing. Good luck
May 21, 2007 | Philips 60PW9363 60" Rear Projection...
Red Lines On Screen of Hitachi 43FDX01B
can we see a picture of that?? I dont understand whatyour saying about the lines.. Are they differant colors or all red and do they make the pic bow?? does the pic look or have a reddish tinge to it?? is ther too much red in the picture??? Please let us know or let us see??
Apr 11, 2006 | Hitachi THE SOLUTION 3511 Projector, Mount...
RCA P61960 61" Rear Projection Television Logo
212 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
