Question about GoVideo DVR4550 DVD Player / VCR Combo
My DVD will not eject..GoVideo DVR4550
My DVD will not eject...I've turned player off/on...no luck. I've unplugged/re-plugged, still no luck. What can I do?
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
Drummernick
  • 440 Answers
SOURCE: Degraded Signal quality
u would need a s video or coumpunt cables going into it
Posted on Feb 06, 2008
SOURCE: dvd player wont eject or load..........
http://www.fixya.com/support/t208832-lite_lvc_9016g_dvd_drawer_not_open
Posted on May 22, 2008
SOURCE: LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Posted on Jul 20, 2008
mrgreenz
  • 962 Answers
SOURCE: Disc won't eject, play, turn off- only screen is initial lg logo
You may have to replace the lens on the player. O replace the entire DVD player. You may be able to find one online. be sure to give all the information possible.The problem is that the lens is not reading the digital information.
Posted on Feb 06, 2009
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
The dvd door doesn't open
plug out the player for 5min from wall power and then plug in.
else you wil have to open the player and push it out manually.
Sep 04, 2008 | GoVideo Televison & Video
GoVideo vr 2940 DVD drawer will not open. It has a DVD in it.
Pull the power plug from the unit. Wait a minute, then plug it back in. If it still won't open, you'll have to take the player apart to get it out, UNLESS it has the eject port on it - some do. Look around the DVD drive for a small hole, about the diameter of a paper clip. If you find one, straighten a paper clip, unplug the player from power, then use the straightened paper clip by pushing it straight in to the hole, which should trigger the emergency release.
Good luck.
Jul 06, 2011 | GoVideo VR2940 DVD Recorder/VCR
DVD tray will not open. Lock is not on. I have tried unplugging the unit then plugging it in again. What do you suggest?
I think your DVD player is trying to read the disk, but it can't. Try unplugging the unit. Holding down the eject button and plugging it back in. After it begins to to power up you can release the eject button. What your wanting to do is to get it to eject before it tries to read the disk. Good luck.
Apr 20, 2010 | GoVideo DVD Recorder/VCR with YesDVD
System will not eject video tape and is locked
This unit is confused. The timing may be messed up. Try unplugging the unit for 1/2 hour. This will force a system reset and make the unit go through a complete startup check/reset. This may clear it up. If not, hopefully the symptoms will change slightly. Please post the results of the "reset".
Thanks,
Dan
Nov 03, 2009 | GoVideo DVR4000 DVD Player/VCR
DV2140 DVD player door will not open.
Most manual overrides involved pressing and holding either the eject button or the power button on the machine itself (not the remote). Try those first.
If that doesn't work reply with the following info:
Will your system turn on/off?
Are you able to play the disk that's in the drawer?
Jul 09, 2009 | GoVideo DV2140 DVD Player/VCR
Dvd & vcr DV2140
TRY UNPLUGGING THE UNIT FOR A FEW MINUTES.SOMTIMES THIS WORKS.
Nov 01, 2008 | GoVideo Go Video DVD/VCR Combo
Region change to multi on govideo #DV1140
This might help some...no gurantees...... take care...
Kevin
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  1. Open the disc tray
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Jul 18, 2008 | GoVideo D645 DVD Player
The dvd player will not eject the dvd
We once had 2 DVDs in the tray (thanks, kids). The tray would not open and had similar symptoms.
We eventually pulled/pried-open the tray (while it was attempting to open by itself, aka you could hear the try motor was activating.)
I'm sure a tech would cringe at this, but it did eventually pop open (with our aggressive help) - and all is well.
Good luck.
Jan 05, 2008 | GoVideo Go Video DVD/VCR Combo
GoVideo DVR4550 DVD Player / VCR Combo Logo
56 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
