Question about Toshiba 50H82 50" Rear Projection Television
Toshiba 50H82 blue arcing?
I have a Toshiba 50H82 rear projection TV that is just five years old. The other night I was watching TV and a blue arching light stream appeared which distorts the lower part of the screen. It also causes a ghost blue shadow when either numbers or letters appear at the bottom of the screen.
I already bought a new Samsung 47" but would like to attempt to fix the Toshiba on my own. Any suggestions?
  • bandit366 Dec 18, 2007
    For us novice, what is a CRT deflector and where is it located?
    Can it be changed, cleaned or what?
  • Anonymous Apr 01, 2014
    What would be causing these red and blue shadows? The faces are not distorted but they have this red and blue running thru them.
  • 1,030 Answers
Color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Posted on Dec 18, 2007
  • Willie Howell Dec 19, 2007
    crt is the "picture tube" what you need to look at is convergence amps..the crt is something not for the novice. Convergence is ideal set up at the factory. in a special mode. usally there is two cuicit called ic that go bad. or in your case mabe 1. since its only the blue bad.
How do I know I need a new projection lamp? My tv
This set does not have a lamp. It has 3 crt tubes that converge to create a color picture. The convergance is off a little causeing this affect. Go into the menu and look for convergence or magic focus. You can download the owners manual from Toshiba website to do this. You will need the remote that came with the set.
Nov 30, 2009 | Toshiba 50H82 50" Rear Projection...
When I turn the tv on it flickers and there is a
Cold solder joint on the board. Time to call a TV tech..
N Sabre
Nov 08, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Green screen
There is a good chance that it is a bad CRT or a bad CRT Driver Board.
Hope this Helps,
Jul 04, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
Jan 14, 2009 | Toshiba 50H82 50" Rear Projection...
Old toshiba
Hi Veronica,
I need to know exact model number of your Toshiba TV to help you out.
You can find it at back of TV on some kind of sticker.
Oct 11, 2008 | Zenith R49W36 49" Rear Projection HDTV
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
50 inch screen
I will check when I get to work tomorow and see if we have one and I will repost tomorow
Apr 17, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
306 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
