Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Line on the monitor - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
  • 53 Answers
U have a crack in ur screen
Posted on Sep 29, 2009
Display lines
check your IDE or SATA cable and your memory
Sep 23, 2011 | Dell OptiPlex 170L PC Desktop
There are 2 lines of color in the middle of my monitor one red and the other line blue. How do i fix this?
It seems the monitor is defective. Try to turn off the computer and check if you see those lines even when the computer is turned off and only the monitor is turned on. You can also see if you are getting those lines when you are in BIOS Screen. If the answer is yes then my dear friend you surely need to replace the monitor.
Jul 17, 2010 | HP W1707 LCD Monitor
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
A black line heavy in the middle at the top right corner of the monitor
check whether Line present during self test, and in Bios screen
If Line present it is Hardware failure, Monitor needs to be repalced
If Line no Present,. Perform Factory Restore
Jan 12, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I got a vertical line on my lcd screen
lines on an lcd screen means the screen itself is going bad, if the monitor is under warranty then get it replaced, otherwise get another one. Also to verify this, try another known working monitor on the computer and if the lines go away then you know for sure the monitor is bad, if the lines stay on both monitors then you know that the video card is bad.
Jan 06, 2010 | Computers & Internet
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
My dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Mar 15, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
Lines are formed in the monitor
unscrew your lcd check the ribbon connector "circuitboard to screen"
Sep 26, 2007 | Acer AL1511 15" LCD Monitor
Red Line
I was just looking at Samsung's site regarding this issue. It is most likely a line of dead pixels. Direct from their site: "The thin red, green, blue, white, black, or yellow line you see running through your LCD monitor is most likely a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced. To set up a service appointment, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your monitor's model number and serial number on hand when you call." http://erms.samsungusa.com/customer/sea/jsp/faqs/faqs_view.jsp?PG_ID=1&AT_ID=15336&PROD_SUB_ID=28&PROD_ID=-1
Jun 21, 2007 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
