Question about Toshiba Televison & Video
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Hello I have a TOSHIBA TP55D80 REAR PROJECTION TV. For whatever reason after we moved into our new home the picture is off. It appears that the screen has ''zoomed in'', for example if I'm watching CNN or ESPN the scroll on the bottom of the screen is cut out of the picture, or the score at the top of a football game is cut out ect.. I have determined that the cable has nothing to do with the problem because when the tv is in regular antenna mode the channel number at the bottom right of the screen is also cut out. I have tried everything possible with the remote and I am just about convinced it is an internal problem and possibly something that was damaged during the move. PLEASE HELP!!! Thanks Jordan. My email is jungusjordan@yahoo.com
    Scholar:
  • 146 Answers
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Posted on Sep 28, 2009
Toshiba theaterwide tv turns on and off on it's own and picture is messed up
I presume you unplugged set for a while and plugged it back to see if problem clears (allows set to reset).
If whatever picture you see looks 3d or colors skewed that is convergence problem.
Apr 20, 2012 | Toshiba TheaterWide 46HM84 46" Rear...
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
Toshiba TP55D80 rear projection has sunburn
nope...get a new one, my call..unless you like to do this a lot..
Mar 11, 2008 | Televison & Video
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
I recently picked up a Toshiba TN50V71 & am not sure where to start in troubleshooting it. There is no picture, & the led power light is steadily red.
Rear projection TV is made up of a TV, optical lens and a screen. So picture projection problems are from the small TV tube. Take off the back to reveal the TV and see what could be replaced?
Aug 16, 2010 | Toshiba TN50V71 50" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba Rear Projection Tv 40WH08B
If the convergence on one or more color does not align using the convergence setup procedure, that means that one or more convergence ICs must be replaced, that is the reason why you get bad picture.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 10, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Picture moving from top to bottom
you have a defect in the vertical circuit. most likely the vertical chip ,caps,diode and supply voltage for the chip..john
May 28, 2007 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
268 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
