Question about Logitech Driving Force Pro (963293) Wheel And Pedals Set
Brake-gas crossdeed after a lap or two (GT%) brake will begin to apply car slows down gets worse until car will not move-spins tires etc.
  • deadoaks Dec 28, 2007
    The brake seems to be slightly applied even when full throttle is on and no brake is being pressed. Performance suffers.
  • 3 Answers
The problem is dust inside the pedal potentiometers, just take apart the pedal box, make sure the pedals are facing downward when you remove the bottom cover, otherwise the springs are going to pop out, once inside you will see the inside on the pedals, a couple of springs and two potentiometers (where all the wires connect to) take one of these out carefully and spray the hell out of it with WD40, turning them with your fingers back and forth all the way, put it back in and repeat the process with the other one, make sure they are in the same rotation position when you put them back in and make sure they seat properly before you put the back cover on. this will fix the problem, if problem keeps coming back just take one out and go to your local electronics store and get replacements just make sure you wire them like the originals
Posted on Dec 08, 2008
I fixed my with packing foam (the firm plastic type). The silver spring somehow got compressed overtime and therefore not able to apply enough force to push the break paddle upward.
1. Remove the bottom of the paddle (remove the 9 screws). Be carefully when removing the bottom so you know how to put everything back together.
2. You will find a silver color metal spring (not the black one).
3. Cut a piece of foam about 3/8" width, 1" length and 3.4 thick.
4. Punch a hole in the middle of the width along the length of the the foam.
5. Insert one end (the end on the gas paddle) into the hole in the foam. The foam should fix nicely within the gas paddle piece.
6. Put everything back together.
Posted on Sep 15, 2008
Http://merc460racing.com/GT/repairing_logitech_driving_force.htm
Posted on Mar 27, 2008
Clack..clack.. clack noise when lightly applying brakes. front passenger side
That is the brake pads slapping in the mounting bracket . When the brakes where done did they use new mounting hardware > Did they lube the contact points for the pad slides etc... Your better off taking it to an ASE certified repair shop , not a tire an brake shop . Or the ford dealer .
Mar 12, 2016 | 2006 Mercury Grand Marquis
1991 GMC Jimmy has vibration at around 50 MPH.
get your tires checked definitly sounds like a balance problem could be a bent rim also
Apr 06, 2015 | 1991 GMC S-15 Jimmy
How to adjust parking brake on 1993 chevy lumina ?
  • Adjustments
  1. Apply service brake pedal three times with a force of approximately 175 lbs.
  2. Fully apply and release parking brake three times. Full application may require two pedal strokes.
  3. Raise and support vehicle, then mark relationship between wheel and axle flange.
  4. Check parking brake pedal assembly for full release as follows:
    1. Turn ignition switch to On position.
    2. If ``Brake\'\' lamp is illuminated, operate manual brake release and pull downward on front parking brake cable to remove slack from pedal assembly.
  1. Remove rear wheel and tire assemblies, then install two lug nuts to retain each rotor assembly.
  2. If two parking brake levers on both calipers are not against lever stops on caliper housings, check for binding in rear cables and/or loosen cables at adjuster until both left and right levers are against their stops.
  3. Tighten parking brake cable at adjuster until either the left or right lever begins to move off the stop, then loosen adjustment until lever moves back barely touching stop.
  4. Operate parking brake several times to check adjustments. A firm pedal feel should be obtained by pumping pedal two full strokes and rear wheels should not rotate forward when parking brake is fully applied.
  5. Install wheel and tire assemblies, aligning marks made in step 3.
Sep 06, 2014 | Cars & Trucks
Steering wheel wobbles and tires seem to wobble as well
Jack it up at each wheel, spin the wheel, watch it to see if it is out of round, if there might be a bubble in the tire anywhere, (cords break inside the tire), or if the rim is bent. Use chalk as it spins to locate slight flaws. Compare wheel to tire while spinning. Check to see if the wheel is loose either at the hub, axle or lug nuts. Make sure your A frame or tie rods are not coming loose. Use pry bars to see if everything is tight. If your wobble is only when braking it is probably a un-evenly worn brake rotor. Always chock (block) your wheels and apply emergency brake while jacking up a car. Take your time and be safe. Do not get distracted if you are running a jacked up car. Apply brake before moving shifter back to park to stop spinning wheel.
Feb 12, 2014 | Cars & Trucks
2002 grand am gt sedan right front clack, and popping when turning or slowing down
If you hear a clacking sound esp. while turning. Sound like your CV joints (constant velocity) or Front Wheel Drive axle.
Apr 13, 2013 | 2002 Pontiac Grand Am
There is a weird grinding noise come from underneath my subaru. The sound seem to be coming from the fron passegner side, and stops when I apply brakes(even a slight touch of the brakes. Thak you.
jack up car on passengers side and see if tire is tight, it may be a bad wheel bearing. to check, see if there is any movement in tires. rotate the tire and see if noise is there. a way to check for a bad wheel bearing is to jack up tire, then apply emergency brake and put foot on brake start car and put it in gear ( foot on brake ).release the brake real slow and the tire will spin,do not give it gas, so you can tell if the bearings are bad. be careful not to let car lurch forward! if not the bearings. you may have a worn brake pad on that side etc. good-day !!
Aug 09, 2011 | 1991 Subaru Legacy
How do you increase gas mileage on 2000 lincoln ls?
clean the inyectors and change the spark plugs
Jan 29, 2010 | 2000 Lincoln LS
I have a camaro and the light of low trac comes on so i want to know what it is
Low traction means the the on-board computer has detected that one or more tires are rotating at a different speed.
If this is occuring randomly, or constantly, you have a problem, that on a camaro (I assume a 2010) should be under warranty.
If this only occurs when you are burning rubber and impressing the ladies in the car next to you, then you are creating the problem by spinning the drive tires at a different speed than the other tires.
If you are driving in ice, snow, rain, etc., it could just be doing its job. Normally, when this occurs, one or more things should occur:
Brakes will be applied to the offending wheels to slow their spin or the engine rpms will be limited until the tires are all spinning at same RPMs.
Aug 12, 2009 | 2004 Chevrolet Cavalier
Slight shimmy while driving, but intensifies when braking
This could be caused by worn front end parts, and or unbalanced tires. to test with engine off the key in the ignition switch turned to the run position turn the wheel back and forth not enough to move the tires, if the steering wheel moves more than 2 inches then you have a problem and I can tel you how to test the front end parts to determine how to fix. If it's worse with the brakes applied then it is just amplifying the problem.
Jul 16, 2009 | 1997 Ford Escort
Logitech Driving Force Pro (963293) Wheel And Pedals Set Logo
413 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
