Question about Dryers
Dryer is not drying. Vent is not clogged and dryer will not heat up at all.
  • Michael Masters
    Michael Masters May 11, 2010
    You did not indicate the actual build. Is it gas or electric???
  • 61 Answers
Check your heating element and your thermostats
Posted on Sep 28, 2009
Dryer only heats max on and off i do not here it kicking in at times. takes up to 1 to a half hours to dry a load
The most common problem for long dry times is a clogged dryer vent. Make sure your dryer vent is cleaned. When the dryer vent is clogged, it does not allow the dryer to circulate the air
Jul 12, 2011 | Dryers
Will start, won't completely dry our clothes... Taking FOEVER!!!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 01, 2011 | Dryers
Leaves burn marks on clothes
Hello there:
There are normally 2 main causes for this to happen
first if it is overheating or if it is taking to long for the dryer to dry the clothes so plese check these solutions that i have provided below ok and keep me posted on this
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged clear it using your vacuum, . Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system.
May 14, 2010 | Frigidaire FDE546RE Dryer
Dryer is taking multiple cycles to dry average weighted clothes/
Make sure the dryer heats up and that the proper cycle is selected. If the dryer doesn't heat, the cause will need to be determined. This can be an ignitor issue, the timer, or a gas supply problem.
If it's heating, check the vent line from the dryer to the outside of the dwelling for lint clogging. Also check the diverter (flapper valve) at the dryer vent outlet to be sure it opens all the way and that the air stream is pretty strong. Lint clogging is one of the most the most common causes of dryers not drying very well or taking an extended drying time period.
If the vent line is longer than 20 feet and has multiple bends, backpressure in the line can cause additional clogging.
Jan 25, 2010 | Whirlpool LGR3624JQ Gas Dryer
Laundry not getting dry
Vent
Heating element
Internal ductwork
Cycling thermostat
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
Our dryer takes multiple cycles to get clothes dry. Eventually the clothes dry, but it takes forever.
If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But?if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
Jun 12, 2009 | Whirlpool Dryers
Dryer is not drying clothes as quickly
Hello. I will briefly state all of the possible reasons why your dryer is slow but I will first say that the common reason under the circumstances you state is that the vent pipe is either partially clogged with lint, or partially blocked, or it has more bends and turns in it than you had in your previous residence. I would begin by pulling the dryer out, removing the vent pipe and checking inside the back of the dryer and in the vent pipe all the way to outdoors.
Vent
Heating element
Internal ductwork
Cycling thermostat
May 31, 2009 | Dryers
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
May 20, 2009 | Dryers
Heating element stays on
Vent
Heating element
Internal ductwork
Cycling thermostat
Mar 07, 2009 | Whirlpool LER7646J Dryer
Dryer want heat
If the dryer is heating but not drying it is because of a clogged up dryer vent so disconnect it from the back of the dryer and if clothes dry then your vent is clogged and needs cleaned or replaced. please rate me
Jan 09, 2009 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
