Question about Minolta CF2001 Copier
Minolta cf 2001
I AM GETTING A SERVICE CODE COF37 - 1 CAN RESET UNIT BY OPENING AND CLOSING DOORS BUT AFTER A FEW COPIES THE ERROR COMES BACK - I CAN TELL THAT NONE OF TONER HOPPERS ARE DROPPING TONER BECAUSE THE MOTOR TO DRIVE THEM IS NOT TURNING - IS THEIR A OUTPUT PROGRAM I CAN TEST THE MOTOR - I ALSO SWAPPED TONER SENSORS ON TONER BOX
IF YOU CAN ASSIST ME IN GETTING THIS PROBLEM SOLVED PLEASE HELP YOU CAN CALL ME AT 614 446-0744
  • 146 Answers
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Posted on Jan 04, 2008
  • Brian Bell
    Brian Bell Jan 04, 2008
    you can try to make solid black copies to pull the toner level down in the black DV unit. I have seen this before and the problem did come back. I will look back in my files and see what the fix was for it and post data as it becomes available.
My c451 konica minolta printer is show error code 4501
Open close front door. to reset. if code comes back your Print head is bad. The print head houses the LASER for each drum. ITS ONE UNIT
Mar 13, 2017 | Konica Minolta Office Equipment & Supplies
My konica minolta c541 printer is show error code 4501
mam, Open close front door. to reset. if code comes back your Print head is bad. The print head houses the LASER for each drum. ITS ONE UNIT
My konica minolta printer is show error code 4501
sir, Open close front door. to reset. if code comes back your Print head is bad. The print head houses the LASER for each drum. ITS ONE UNIT
How to reset Konica Minolta bizhub c203 colour copier c-2558 error
Black image unit, Is the black image unit OEM or third party? Remove the unit and replace. is the Toner OEM? or third party? remove and replace with OEM parts. Open close front door to reset code. If comes back get a tech out to look at could be a bad Sensor.
Nov 06, 2015 | Konica Minolta Office Equipment & Supplies
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
C-0500 error
Sir/mam your going to open the front door at the right below where you keep the cleaning pads if there still some left any way get down on the floor and look up you will see a small hole that leads to a small switch will need a small screwdriver/long with the machine on press that button then close the door. you should see trouble reset touch machine should go to normal if the code comes back do not continue to rese you are resetting the fuser (Hot part) can catch on fire have a tech look at it. Mite need a new fuser Also check and make sure that the two latches that hold the right door to the machine are not broken after years of closing and opening they can break the c500 code also mean that the 120 VAC power is not getting to the fusing lamps that heat the rollers in the fusing unit.
Jan 16, 2014 | Minolta Office Equipment & Supplies
Minolta Copier EP 6000 copier error codes: C:C0010, C:C0992, C:C0410. Any ideas what these mean?
As for the C0992 code that deals with a paper draw fault, looking at the control panel do you see a small wrench located at the left hand lower corner. Touch it , it will take you to another screen when there open and close the front door, if the code comes back you have problem with main draw.
The C0410 is a problem with the very, bright lite under the big glass is bad. try to reset, open the front door to your left is a small access plate open and press trouble reset, if the code comes back replace the exposure lamp.
C0010 code main motor fault, remove the fuse unit the hot part and check for broken gears check the section where it goes look in the back for broken gears, remove the drum assy. check for broken gears, open close the front door to reset, If it comes back get a new main motor and or main control board,
Dec 03, 2010 | Minolta Office Equipment & Supplies
My Minolta CF1501 is showing error COF 34
Before doing above open and close the front door. The code is for the Auto Toner Density Control the black image unit if it comes back after opening and closing the front door the image unit needs replacement. You can't change the developer it is all one unit. the fuser has a different code 500 series. Dont mess with gain let machine run stablize.
Dec 24, 2009 | Minolta CF1501 Copier
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
Minolta Dialta Color CF 2002 MAL FUNC C-3C50
c3-c50 is a money bank code. It means that someone tried to copy money on the machine. U need a minolta code to reset it for good but it works by just opening and closing the front door, certainly the code will reappear.
Apr 25, 2009 | Minolta Office Equipment & Supplies
231 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
