Question about Craftsman Garden
Where is the oil drain plug for a craftsman mower model 917376460
  • 437 Answers
The drain plug is underneath the mower where the blade is. pull the spark plug wire, take the blade off, then take a 3/8" ratchet with small extension and you should find a plug in the bottom of the engine to take out and drain the oil.
Make sure when you fill it back up it should only take 20 ozs. of oil to fill it back up.
Posted on Sep 28, 2009
  • Habeas Opus Sep 19, 2010
    Helpful, but what kind of oil should I use? Standard 4-Cycle 10W40 or something heavier or lighter?
WHERE IS THE PLUG TO DRAIN OIL FROM A CRAFTSMAN 550 SILVER EDITION LAWN MOWER?
Almost all drain plugs are under the deck. Some are a 4 sided nut sticking out and some are an inner plug (looks like an allen shape plug)
Oct 14, 2014 | Garden
Serial number craftsman lawn mower model number 247.370341
If you have a Briggs and Stratton engine and there is no clutch then start your machine and warm it up ( a couple of mins) Turn machine on it\'s side with the air filter UP. Loosen the plug on the bottom of engine and turn mower back upright over an oil tray or suitable container to catch the oil. When done draining reinstall plug and add oil 30W. If you do have a clutch under the deck then warm your engine ,shut down and remove the oil dipstick. Turn mower on side over a tray and your oil will come out of fill tube
Jul 23, 2014 | Garden
Craftsman mower
take the filler cap off, turn mower on its side and drain into a shallow container of some sort. Many mowers do not have drain plugs and this is the way to do it.
Jun 08, 2013 | Garden
How to change oil In a craftsman lawn mower, that has a honda engine. Misplaced my manual. Have decided to change my own oil rather than have it serviced every year I was doing a number of lawns so I had...
Look for a drain plug under the deck in the bottom of the engine (under the deck) known as the crankcase housing. Drain plugs come in different forms, but you will know it when you see it. IF there is no plug on the engine bottom, then check for a small plug on the side of the engine (above the deck) with a square head. That would be removed and the mower tilted that way to drain the oil. If no plug on the side of the engine then the oil will have to be drained out the oil filler tube. Remove the dipstick and tilt the mower that way to drain the oil.
May 15, 2011 | Craftsman Garden
Looking for owners manual for Craftsman model 917.388551 - push mower rear discharge, specifically to change the oil.
FIRST OF ALL, TAKE THE WIRE OFF THE SPARK PLUG!
Well, on the bottom of the mower there will be a small square receptacle, the size of a socket wrench ratchet. That is the female portion of the oil plug. You can use your ratchet to loosen the oil plug and drain the oil. After it has drained, put it back in, but don't put a lot of muscle into tightening it. It will stop all of a sudden, and that will be tight enough. It could easily strip the oil plug as it is more than likely plastic.
This setup is not too handy for draining the oil, so you may want to get creative. I have known some folks to put the front of the mower on jack stands, and the rear on a box or something similar to get it up a foot or so. Try to turn the blade so the oil doesn't run over it and make a mess. Your mower will probably take 12-20 oz of oil. 30wt will be fine. Get a name brand oil, or buy Briggs and Stratton oil (3 times the price, and the same oil as auto stores sell).
Aug 09, 2010 | Craftsman Garden
Need to know how to change oil
the drain plug should be on the side of the engine that the muffler is on near the bottom of the engine, may look like a small pipe with a threaded cap. remove cap and drain oil into a pan. when empty replace cap. remove the dip stick and pour about a 1/4 quart (to start) and check for level, if still low add more (little at a time) until it reaches the full mark...good luck
Apr 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil drain
Under cutting propller box
Jul 07, 2009 | Garden
I've been given a Craftsman Eager 1 6.5hp mower (front wheel drive)and I can't locate the oil drain plug.
On a walk-behind mower, the oil drain plug can usually be found on the underneath side of the deck. The drain plug usually has a square head.
Jun 23, 2009 | Garden
Oil drain plug how do you find it
the oil drain plug is underneath the motor by the blade you can use the socet wrench to open it
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
360 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
