Question about Whirlpool GGQ8831L Gas Dryer
How many BTU are needed for a whirlpool GGQ8831 Gas dryer
  • 15,935 Answers
355
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
I have a Maytag performa poropane dryer. It states the input rating at18000 btu per hour. I have a 5/8 inch OD flexible gas line at 48inches long it is rated for 75001 to106000 btu/hr . Is this the right...
Hi and welcome to FixYa, I am Kelly.
There is nothing wrong with using a larger flexible gas line than is required. We used the 5/8 OD lines most of the time as they were much more durable than the smaller ones. The line you have is fine.
Thanks for choosing FixYa,
Kelly
Feb 09, 2011 | Maytag Dryers
Whirlpool Gas Dryer I need the wiring diagram of Whirlpool WGD 5000
Here is a link to your diagram, Whirlpool prints both gas and electric models on the same page, since yours is gas use the bottom diagram.
Let me know if you have questions.
Tech_Sheet_01_20_2010/Wiring%20Sheet%20-%20W10185979.pdf
May 05, 2010 | Whirlpool Dryers
Gas dryer turns on but no heat?
I HAVE A WHIRLPOOL GAS DRYER I CAN SEE IT GET RED IN THE BACK FOR ABOUT 5 SECONDS AND THEN GO OUT THEN THE IGNITER CLICKS BUT DOES NOT LIGHT THE FIRE.
Dec 25, 2009 | Whirlpool LGR5636L Gas Dryer
Our Whirlpool dryer GGQ8831 dries too hot, even on the extra low setting. I do not use the sensor to dry clothes anymore, either. We don't know if it's due to the ductwork (possible inadequate air flow) or...
You most likely need to replace the cycling thermostat located on you duct inside the dryer. If you continue to use like it is, the high limit will end up going out. When it does the dryer will stop working al together. There are two that you need. If you go to parts select.com. enter your model #. It will bring you unit up. Click on Bulkhead parts picture on right. you will need part number 42 and 43. These are cycling thermostats. One is a lower heat and the other is the medium and high heat. what you running on at this time is the thermal cut off. When is goes bad it will put the thermal fuse out, cutting the whole machine off. I hope this helps. No to worry, these are common parts that go out from time to time.
Oct 10, 2009 | Whirlpool Dryers
Convert Whirlpool dryer from propane to gas
You must purchase a conversion kit from your appliance parts store.
Mar 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Jdr8895aas
This is the solution to convert from LP back to natural gas that I posted as a comment on this thread:
After much work and little help from Jenn-Air or Whirlpool, I found a satisfactory solution. As many of you may have found out, Whirlpool does not sell the natural gas orifices to the JDR8895AAS separately as they do the LP conversion orifices. Instead, they recommend that you buy all 5 orifice holders that include the individual orifices. This would run about $120-150 depending on where you shop. If you want to take this route, the Whirlpool parts you need are:
1x740079621x740078132x740079611x74007816
Fortunately, because natural gas is denser than LP, the LP orifices can be bored out for a conversion back to natural gas. After a lot of homework I was able to find someone with the natural gas orifices for this stove that let me take them out to measure them. For some crazy reason, Whirlpool does not have this information:
Find a machine shop or a good appliance repair shop that has a wire gauging bit set. The natural gas orifice hole sizes are as follows:
Left front burner (16K BTU): 48Left rear burner (9.2K BTU): 54Center burner (5K BTU): 58Right front burner (12.5K BTU): 52Right rear burnger (5K BTU): 58
It cost me $25 to have these resized after I found the correct hole size.
Finally, to complete the conversion back to natural gas, you must flip the plastic screw-shaped piece by unscrewing the hex nut on the regulator at the back of the stove.
Hope this helps, because it took me a while to figure it out.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Whirlpool GGQ8831L Gas Dryer Logo
165 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
