Question about Ryobi Backpack Blower 25.4cc
Ryobi blower will not start unless primed by
Ryobi blower always been difficult to start. Now will not start unless primed by covering carb inlet and pulling starter a couple of times. Then runs fine for 10-15 seconds then stops. Looks like fuel starvation though primer works great, fresh fuel in the tank and a new plug. Are there issues with this type of carb?
  • 437 Answers
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Posted on Sep 28, 2009
Testimonial: "Great reply thank."
  • 22 Answers
Fuel filter inside gas tank is possible stopped up....remove gas cap take a peice a wire with a 90 on it and pull fuel filter from gas tank disconnect from hose and replace with new...
Posted on Sep 29, 2009
I have a ryobi rpt 320e grass trimmer. my question is when pushing the prime bubble , should fuel come out of the small hole on the plate under the diaphram bowl.
the small hole should have a line attached to it so fuel goes to the carb --the bulb --has inlet from tank to bulb -outlet from bulb to carb
Nov 24, 2016 | Ryobi Garden
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
Can not get Husqvarna 150BT to start. Brand New out of box.
turn it on, add fuel, prime carb, set choke and start... usually like that it works unless you primed it and flooded the engine
Oct 23, 2013 | Husqvarna Hand Held Blower 125 B Grass...
I have a Ryobi PBV-30A Blower and require a diaphragm kit. It is fitted with a Walbro carb, however, I cannot tell which model of carb. Can you tell me the Walbro model number/type? Thanks Marc
If you clean the dirt off the carb, the series no. and model no. will be etched into the body of the carb by the fuel inlet nozzel.
Feb 09, 2011 | Ryobi Garden
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
Replaced primer bulb and gas lines will not prime or start
Sounds like you have the lines connected incorrectly. Make sure that the bottom of the carb is connected to the inlet side of the primer (take the lines off and with one of the ports covered with your finger push the bulb, if it collapses and doesn't return then that's the suction/inlet of the bulb). The other side of the bulb needs to be connected to the gas tank. The other side of the carb needs to go to the filter side of the gas tank.
Nov 04, 2009 | Garden
Have 2 gasoline inputs to my walbro carbrator. The one on the bottom closest to the diaphram side leads to the prime botton. The one on the otherside leads directly to the gas tank. When the prime button...
Nov 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower 25.4cc Logo
659 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
