Expert
- Posted on Sep 28, 2009
Re: How do you replace the alternator on a 2000ford...
Removal & Installation
2.0L Engine
- Disconnect the negative battery cable.
- Remove air intake resonators.
- Remove the air cleaner-to-throttle body tube and the mass airflow sensor.
- Unplug the connectors and remove the cables from the alternator.
- Raise and support the vehicle.
- Release the drive belt tensioner and remove the drive belt from around the alternator.
NOTE
It is not necessary to remove the drive belt from the engine.
- Remove the alternator mounting bracket bolts and remove the mounting bracket.
- Lower the vehicle.
- Remove the power steering pressure hose bracket retaining nut and bolt and remove the bracket with the hose from the engine lifting eye.
- Remove the alternator mounting bolts and remove the alternator from the vehicle.
To install:
- Place the alternator into position and install the mounting bolts finger tight.
- Install the power steering hose bracket and tighten the retaining nut and bolt to 70-106 inch lbs. (8-12 Nm).
- Install the alternator mounting bracket and retaining bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
- Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
- Tighten the alternator mounting bolts to 15-22 ft. lbs. (20-30 Nm).
- Install the alternator connectors and the cables. Tighten the terminal nut to 80-97 inch lbs. (9-11 Nm).
- Install the air cleaner-to-throttle body tube, mass airflow sensor, and the air intake resonators.
- Connect the negative battery cable.
To install:
